This look interresting, simple free energy device
Started by TheOne, March 12, 2007, 12:13:12 AM
tosky
Hello All,
One way can find out if I was wrong, First discarge the cap. then do the same charge up experiment with the magnet and cap. but (without the digital meter) for many days. It should be charged much energy. Then measure it with a (needle type volt meter). If it very work it should have something.
I suggest to use the double-blind test for comparison.
I believe to use the antenna may capture energy because it is the same as solar cell panel. But less energy as small scale.
Grim
Just a thought, but the direction of current flow creates a magnetic field around a copper wire.
Does creating a magnetic field around a conductor create current?
Are the capacitors contents being charged by the magnetic field created by the magnets?
Perhaps it is not the capacitor as such, but its internal conductors...
I had another observation to make but I forgot in the time it took to write this!
psychopath
Er, I think you would likely get the same results without the magnets. Someone should make a more scientific video.
Grim
Remembered it!
Would the Earths magnetism charge a capacitor normally?
Just some questions that a comment or two might help me work through...
pese
The device from icestuff is wrong in designg
Schematic . i seen that + an S  must be change in contact wirings  !!!
the schematic from oupower shon right  !!
an electrotastoc charge will upload the antenna wire (sometimes )
if the voltage comes over 1000Volt (djustabes on the spark-gap
. So the voltage will discharge (by fireing the spark) via the
(ignion)-transformer low voltage peaks to the battery.
i think it will take an lot of time to fill an 1 KW  car battery.
12v 84 Ah  are equivalent to 1 KW Energy
Pese
www.pese.cjb.net
Quote from: pg46 on May 08, 2007, 01:43:33 PM
and here is another diagram from a researcher over at oupower.com  just scroll down until you find it there amongst some of his other works.
http://www.oupower.com/index.php?dir=_Other_Peoples_Projects/thrival/electronics
