New vids on Stan Meyer!
Started by buzneg, March 17, 2007, 03:18:06 AM
Tripled
Quote from: IronHead on April 05, 2007, 09:37:42 PM
Building IR laser and apparatus in the hot zone now.
This cell is built with the utmost precautions and  in a very small
apparatus, about the size of a D cell battery. This is an open cell
design in case of massive production the cell will have no chance
to pressurize. The Hot zone is a lab area with the proper ventalation
shielding and control to do such a build.
Just Build It
IronHead
The Cell is strickly for producing the "Gas". All treatment of the Gas is done in a seperate apparatus, down stream of the cell.
The laser is not for producing more Gas, but for increasing the energy level of the gas produced. The more "energized" molecules become more "unstable" in a reactive kind of way, making them extremely volatile, hence the need to thoroughly mix exhaust gases (being inert) to prevent a reactence between the Hydrogen and Oxygen.
Quote from: Stanely Meyer-The Birth of New Technology
The Energy Contained in a gallon of Water, exceeds 2.5 million barrels of oil when equated in terms of atomic energy.
In other words, do not laser the reaction cell. You would need a burner setup with an exhaust "piping" plumbed to mix with the "laser" conditioned" gases.
Tripled
IronHead
yes this cell is 2 parts the upper part is where treatment is happening.
Adding exhaust gases  hmm I did not think of that , Adjustments will be made for exhaust inject in to the treatment chamber .
On the bench what do you think about using CO2 as a stabilizer?
buzneg
I uploaded some more video's. This is a 4 Part vid.
http://video.google.com/videosearch?q=stan+Meyer+-+New+Zealand&hl=en
the other's will be up in some hours
Tripled
Quote from: IronHead on April 06, 2007, 01:40:26 PM
hm, i think if your going to get into this territory, you should do a small I.C.E setup. You'll know if your on the right track with laser priming if it runs without a spark.
If you get it going, then use those exhaust gases for "blocking", which would give you inert gases for the mixture.
Chicken or egg?
This would be a test for the priming of the gases. He's not using "explosive gas" output as a "catch phrase" ;) If you have a proper conditioning cell setup, and working with an I.C.E, the you know it's a viable solution.
Well, except for the $450.00 starting price for those diodes....
This "priming of the gas" can also be accomplished without using these laser diodes. As demonstrated with his Injector.
Tripled
IronHead
I agree
The 760 and 820 Laser moduals are on the way. I will buy them all if I have to. These all use the same power supply.
So they will be socket fitted to change them out when I get that far along.For now they are just stock till everything else is done.
One Step at a Time
IronHead
