free electricty from crystals
Started by innovation_station, March 17, 2007, 05:48:04 PM
innovation_station
Quote from: CLaNZeR on May 08, 2010, 06:04:49 PM
[A author=innovation_station link=topic=2107.msg240760#msg240760 date=1273343378]
now thats what im talking about !
touch it with your hand
Na using your hand is cheating  ;D
If you ever attach small pickup coils to a rotor and attach voltage probes you will see a small voltage being displayed. But simply by touching one of the probes with your finger, you can make the voltage jump upto 4-5 times.
Will leave it balance out overnight, but I suspect it is either energy trickling from the meter probes or the caps settling to a small steady voltage.
11:04 pm here and it upto 0.16 volts, so slowed down a bit :)
All good fun as usual
Cheers
Sean.
lol
i wouldnt term it cheating .. i would term it SELF RUNNING ... : )
LOL BY THE FIRST HUMAN TOUCH ..
charge the cap ... hook it to a unit that runs with gain ...
i have a unit or 2
ist!
CLaNZeR
Quote from: gyulasun on May 08, 2010, 05:12:28 PM
Now wait and see later how the caps recharge themselves, I forecast the two voltage values you would find in the end will be pretty much the same in both caps, the crystals would have nothing to do with the recharge effect...
rgds,  Gyula
Hi Guyla
I shorted two caps so they were both 0 volts before I started this test.
One I connected the Xtals and the meter, the other I left on the side.
The one with no crystals have crept upto 0.08v and the one with the crystals has gone upto 0.16v.
But then it has had the volt meter connected to it !
Cheers
Sean.
http://www.overunity.org.uk
gyulasun
Quote from: innovation_station on May 08, 2010, 05:40:09 PM
i dont dispute your tests ..
i did my origonal tests  BY TOUCHING THE CRYSTAL ..
WITH OUT TOUCH 0 OUTPUT ..
touch it .. it amps as i have explained ..  agin this can go any number of ways ...  meaning earth ground and antenna or coil or .. well NO LIMITS ..
William,
I do not dispute you have seen the DC milliVolts (even some hundred mVs) on your multimeter as you described earlier in this thread.  I also believe you do not see milliVolts when you are not touching the wires or the crystal wires etc.
Why do you use the amper word here I wonder, there is pico or maximum nanoAmpers involved, just think it over: Your multimeter has a 10 MegaOhm inner resistance in its DC ranges and you see for instance 200mV. Then what current level is involved? Ohm's law says it, no?
rgds,  Gyula
gyulasun
Quote from: CLaNZeR on May 08, 2010, 06:10:39 PM
Hi Guyla
Cheers
Sean.
Ok, Sean,  thanks.  Yes, the voltmeter with its wires may also play trick here.  But you could replace the two capacitors with each other and repeat the same test, there is no two caps behaving exactly the same.
Or you do not leave any meter wire connection on any of the caps during the test, and after a certain time you check quickly and separately the voltages.
rgds,  Gyula
innovation_station
Quote from: gyulasun on May 08, 2010, 06:20:09 PM
William,
rgds,  Gyula
agin im sorry you have miss understood me  once agin ...
im not talking about amps ...  as in CURRENT !
IT AMPLIFLYS THE VOLTAGE OF MY BODY ..
BECAUSE IT IS A MAGNETIC HARMONIC ENTANGLED WITH IN  HUMAN CONCINOUSS
