Power In Water
Started by Draco Rylos, March 18, 2007, 02:23:18 PM
Grumpy
Freakin toroidal coil...
Well, I'll be damned straight to hydrohell!
        -Frank Edwards
Draco Rylos
yup it uses a toroidal coil to produce the parahydrogen while the electrodes produce the orthohydrogen that acts to slow the rate of burn. The example it gives is that parahydrogen acts like an octane booster to prevent knock.
We are the BORG..... We will add your biological and technological distinctiveness to our own. Your culture will adapt to service US. RESISTANCE IS FUTILE
starcruiser
Quote from: Grumpy on April 05, 2007, 05:52:22 PM
HAHAHAHAHA!!!!! you crack me up
Regards,
Carl
Flit
Quote from: dukenukem on April 05, 2007, 02:04:44 PM
I found out it is 2.5 million barrels of petroleum per gallon of water.
Do you mean that there is an equivalent amount of energy in a gallon of water as there is in 2,500,000 barrels of petrolium?
So for every gallon of petrol my car uses I could be using roughly 49 nanolitres of water instead?
ResinRat2
Theoretically at standard temperature and pressure (25 degrees C and 1 atmosphere):
                  2H2O         --->          2H2         +         O2
        36grams(ml) water  ---->  44.8 Liters H2   +   22.4 Liters O2
Yes that's a total of (44.8 + 22.4) = 67.2 Liters of hydrogen/oxygen mixed gases in the exact ratio for perfect detonation (lol) from 36 ml of water.
I don't know about energy equivalents, but I would say that amount of mixed hydrogen and oxygen gases would make a might BIG bang.
Just make sure you have your earplugs and a kelvar-lined explosion-proof suit.
Actually, taking that a step further, since we get 67.2 Liters of H2/O2gases:
   67.2 Liters gas                     3785 ml water                     7065.3 Liters of gas (H2/O2)
   -------------------   X     ------------------        =      --------------------------
     36 ml water                     Gallon of water                         Gallon of water
Over 7000 Liters of highly explosive gas from a gallon of water is quite a bit of energy. You figure it out.(lol)
