frictionless homopolar generator
Started by innovation_station, March 26, 2007, 08:09:09 PM
innovation_station
yes it is a faraday disc style generator based on the work of faraday with my twist
is
Low-Q
Quote from: innovation_station on April 01, 2007, 08:16:16 AM
i am not saying that it will but frictinoless will improve the op of this unit too this can be built many ways so sorry for my last i just assumed you were making fun or you realy did not understand what im saying
it also seams you are challanging my turbine here it takes almost nothing to turn the ring mag because of it weightlesness so to turn the turbine i will use compressed air mabe use the filsinger squeeze tech pressureizer or a 12v air compresser
the generator will not be limitless it should produce around at the most 3 v but at high current  if i put 2 mags togather ooposing  copper between and spin fast as i can for input i will get more voltage but same current
is
OK I see. Have you consider that there will be a sort of electronic friction between the spinning magnet and the copper disc when you load it or short-circuit it?
Btw: Paul-R/William -> Thanks for clearing up Edison/Faraday :D. I haven't had my brain with me the last few months. Of course  - Faraday! I should have remembered that :-[
Br.
Vidar
innovation_station
the copper disc is connected to the magnet they will both spinn at once as 1 and the weight of the spinning combo will overcome any friction created from drawing a load
so it should not slow down when you take current from it
or if it does slow down it should be almost un noticeable defentaly not come to a stop
is
Draco Rylos
Your idea is a bit more complex than mine, but we both have good ideas that I hope we can get our ideas working.
We are the BORG..... We will add your biological and technological distinctiveness to our own. Your culture will adapt to service US. RESISTANCE IS FUTILE
innovation_station
well why not combine our ideas togather and get somthing real good from it
just a thought
is
