frictionless homopolar generator
Started by innovation_station, March 26, 2007, 08:09:09 PM
Draco Rylos
Sounds like an awesome idea. I had to redraw all of my drawings, because I found some inconsistencies in the drawings, which threw off the rest of my drawings. I have all my IM running so if you want to IM me, you can. I like talking about stuff like that because the wait is reduced.
We are the BORG..... We will add your biological and technological distinctiveness to our own. Your culture will adapt to service US. RESISTANCE IS FUTILE
Low-Q
Quote from: innovation_station on April 01, 2007, 02:10:41 PM
the copper disc is connected to the magnet they will both spinn at once as 1 and the weight of the spinning combo will overcome any friction created from drawing a load
so it should not slow down when you take current from it
or if it does slow down it should be almost un noticeable defentaly not come to a stop
is
So the magnet are spinning together with the copper disc - OK.
1.st: The brushes - how do you get a friction less contact between the brushes and the copper disc?
2.nd: How can you get anything out if there is no relative motion between the magnet and the copper disc?
3.rd: Any friction will require the same amount of, lets call it maintain-energy, to keep spinning regardless of the weight of the spinning parts.
You can look at the spinning mass as a capacitor. The greater mass, the higher capacity, but higher energy required over longer period of time to "charge" it as the mass and diameter (The moment) increase.
I'm not trying to work against your ideas, but I just try to understand how your device would work in my opinion.
Sorry for not having any constructive ideas at this point - maby later  :)
Br.
Vidar
gyulasun
Hi All,
Here is an interesting link on Faraday type generators
http://www.zamandayolculuk.com/cetinbal/faradaydisk.htm
Also, Nikola Tesla indicated to use two disks to easy the friction problem, I attached his patent on it.  He made notes on unipolar dynamos too:
http://www.andrijar.com/teslahom/index.html
And here is some speculations on Tesla fuelless generator that includes his dynamo electric machines and unipolar dynamos:
http://home.earthlink.net/~drestinblack/generator.htm
Maybe someone finds the above links as useful info, but in fact they have been there for several years now..
Gyula
innovation_station
@vidar thanks for your input i have done much reaserch in this feild this is how i redesigned the n machine and adapted it to work with my turbine in the most efficient machine thred trust me it will make power as designed but looking forward to more of your thoughts
is
@gyulasun  thanks for the links i have seen all of them b4 but agin thanks
i beleave in 1 of teslas pattends he used a flat copper wire 2 wraps around the edge of the disc in the same dirrection as the reveloution and in doing this when he takes power from it adds does not take away or in other words cancles out the backtorque
also it will strenthign the mag feild thus the more you take the more it makes
as i said this is much still in the design phase
but all thoughts are welcome
william
Low-Q
Quote from: innovation_station on April 02, 2007, 07:43:53 AM
is
william
OK. I look forward to your final result, and hopefully you'll show us some pictures and videos of the machine (?).
If I come up with any constructive thaught, I'll let you know.
Br.
Vidar
