frictionless homopolar generator
Started by innovation_station, March 26, 2007, 08:09:09 PM
innovation_station
come on how could 2 little wires generate that much current ? they do generate alot of current you know
is
also do some proof of concept tests for yourself cost almost nothing and you will see
william
Low-Q
Quote from: innovation_station on April 02, 2007, 01:06:53 PM
is
william
A wire @ 2 feet long, 1mm2 have a potential to generate loads of current.
When that is said:
I believe there is no energy made in the copper disc itself when it is spinning together with the magnet. However I believe there is energy made between two parts which is having a relative motion in proportion to each other. The only parts which is doing that is the magnet/copper in proportion to the instrument wire. The copper disc is in that case just a conductor so you can have a closed circuit making it possible to measure voltage. Try to load your device, and you'll see that the instrument wire will, in any form of working configuration, be the part which limits the max current available anyway.
In other words, there will never be possible to get more current, in spite of copper disc size, than your wires and the brushes allows.
Maybe you feel counteracted, but my intent is to lighten the problems we probably well meet sooner or later in this process.
Br.
Vidar
innovation_station
yes i quite agree with all you have said in that post
is
Onevoice
Hi guys,
I'm actually working on a similar vein but trying to develop a purely magnetic motivation to start with, then add power generation afterwards.
Word of advice - Beware Faraday's Paradox. It is not the coil\disk moving in relation to the magnetic field, its the coil\disk moving through space while subjected to a magnetic field that causes the resistance. Solve that problem and the rest is easy!
quote: The needs of the one outweigh the needs of the many - Capt. James T. Kirk
Draco Rylos
@onevoice
Innovation Station and I both have ideas along the same lines. My idea is set up completely differently than his. If you want to see what my idea looks like, check out my post herehttp://www.overunity.com/index.php/topic,2128.msg26430.html#msg26430
We are the BORG..... We will add your biological and technological distinctiveness to our own. Your culture will adapt to service US. RESISTANCE IS FUTILE
