Some interesting joe cell clips
Started by buzneg, April 10, 2007, 12:46:44 AM
buzneg
Informative, good info about the nature of electricity. Maybe electricity isn't always just electrons, but photon and protons too? how does the H20 put out just the O on one electrode and just the H on the other electrode? Maybe the protons travel without an electron.
http://video.google.com/videoplay?docid=-3539465122468328116&q=silver+joe+cell&hl=en
http://video.google.com/videoplay?docid=8735378132747719793&q=joe+cell&hl=en
raburgeson
I have some very big reservations about the description of what happens in the engine when it is running at 70 degrees above TDC. I don't except that the engine is pulling the piston because of an implosion. I have a degree in Automotive Techniques and Business management so please hear me out. Engine rings are specifically designed, anyone here that has put rings in upside down will attest to the fact that they are ground to scape and seal the combustion chamber chamber only one way. If the engine was running on a vacuum in the combustion chamber the engine would become and oil pump. Oil usage would be so extreme it would have to be mentioned. These engines apparently aren't using oil so, I go under a different assumption. Compression does weird things to flammable materials including fuels.
Have you ever lit a large fire cracker and the fuse is completely burnt and you have to wait for it to go off? I suggest the fuel is lit so far before compression to allow propagation. This is possible because the engines are reported to run with zero ping. No detonation damage, I think the lit fuel diesels on compression without detonation. What do you guys think? Is there anyway to really tell. Indications still are the fuel air mixture does not implode. Implosion engines using hydrogen would normally have only the correct ratio of hydrogen and oxygen in the combustion chamber because the air in the chamber would not contract and dampen the power produced. My last argument for what is going on in the combustion chamber.
raburgeson
In a different block because it's a different subject on what I thought of the clips. Remember what Tomas Bearden said about neutron energy. That could be coming into play here. No one cares how it works exactly we just need something that indeed does work, let the scientists fight over that after everybody has one. Not just talking about hydrogen on this any project. They won't let you market a breakthrough in any country I know of in the West anyway, so you'll have to open source it and beg donations later or take the ten million and worry about your family the rest of your life. OK, there is a third choice make them mad on the spot and get a very short life span. Success on a project will literally rock the world economy. I watched one video that said if you use 2 neutral cylinders it would cut the amperage requirements in half.
