Simple to make Hilden-Brand style motor
Started by Nali2001, April 13, 2007, 03:40:34 PM
nwman
Hi again,
I hate to post this simple question on this thread but if someone could PM me the reason why the simple MEG idea doesn't work? I plan to build it to test myself in the future but I wont have time for a while and I figures someone probably already has figured out why it doesn't work. It seems to confront all the topics of difficulties the valve has.
-It uses AC so there is no polatiry saturation.
-The core is the same thickness all the way around in all the coils.
-The fields from the Primary coil [A] and the PM are altering in and out of the coils.
-It "should" use less power to move the fields.
-Some of the power used to move the fields can be recaptured in the secondary coils .
Tim
JackH
Hello nwman,
That just might work,   It is a genius idea that you com up with.
Hello   i_ron,
That has already been tested, it has put out about 40% more power out than input..   My main eutectic it to put a motor together that put out Mir power than input.  Right now I in a put out or get out.
Later,,,,,JackH
wizkycho
@JackH
Now tahts a workmanship - we are all Your followers - You completely proved it can be done.
@newman
I allso tought of darlington Magnetic field Transistor - this is one of possibilities. and it --- Works  ;D
This type trafo wan't work if normally switched and extracted cause Mr. Lenz will came up (if current used from B) and with induced counterfield from B coil will stop the cause of high B field and that is field from A coil.
only if A switched veryfast us (mikroseconds) or even ns (nano) and extracting only BEMF from A i B at a same time. for that you need
metglass or any fast_enough core. that is way we shall use mechanicall OUTPUT. no Lenz here, only on generator part but then Lenz can not influence the field from source coil.
these knoweonw ever tried (picture) - if you are eager you could be first - motionless device is holly grail of OU-FE.
keep us informed. these have some logic in avoiding-negating "fooling" lenz
in pic 2 I think toroids must be placed one on another.
Wiz
Ergo
Quote from: wizkycho on October 20, 2008, 03:48:06 AM
You thought of it but haven't built it yet.......and it works! But is it OU?
You never ceases to amaze me.....in the not so positive way. >:(
How does it feel to be more intelligent than all the scientists on earth. ::) ::) ::)
Just to bad you can't explain anything you are doing except claming astonishing results.
wizkycho
Quote from: Ergo on October 20, 2008, 04:38:22 AM
  Nature and Space is the Lord - scientists, me and you can only follow It's rules. scientists ,civilization and humans are stuck in not so beautifull position right now (exp. - one bigger meteor hits Earth and there is nothing left - indeed small but sufficient chance), scientists however are not doing anything to unstuck this, someone else should be invited - You and Me.
No matter how pathetic moves we do, they are allways less pathetic than staying in place waiting for too long for scinetists to help.
(darlington magnetic field transistor.)
If one domino falls and kicks other and makes other fall - it is logicall that fall of the first will eventually result in fall of fifth or fifth thosend
if rules used are same. that is why it works.
It is not hard to be smarter and more intelligent and more civilized human than main stream scientist cause they are swimming in money, and money, most of anything else, makes man and/or scientist stupid. Are you one of those main stream scientists ?
Thank you for your comments. That way you bring this topic with working_OU_motor to top although it is not your attention to do so - you want to see this idea(or any that has chance of working) of amplifing mag. field wanished, right ?
Wiz
