New magnet motor/full rotation/no electricity-just posted!
Started by Bruce_TPU, April 17, 2007, 12:04:17 AM
nwman
IronHead
Well done.
We have to get this guy over here to th forums.
Bruce_TPU
The only thing left off the analysis of the image is what appears to be a large magnet(s) on the fan and duct taped to the center of the brush handle.
Bruce
FreeEnergy
Bruce_TPU
I can not seem to be able to capture freeze frames from youtube to paste here.  But I believe that Stefan was correct in saying there is a magnet or washer on the rim of the bowl that the brush passes over.
This magnet (assumed) can be seen at the following times:
7 second freeze frame
10 - 12 second frames
14-18 second frames
20 second freeze frame
53 - 55 second frames
Any thoughts?
