New magnet motor/full rotation/no electricity-just posted!
Started by Bruce_TPU, April 17, 2007, 12:04:17 AM
TheOne
hum
check the other video posted by this guys
http://www.youtube.com/watch?v=J35JwoTlFvs
i just dont understand because his video dont show any SMOT like this one
IronHead
IronHead
Quote from: TheOne on April 17, 2007, 10:47:09 AM
hum
Hmmmm are those magnetic sheets cut in squares on the table?
http://www.youtube.com/watch?v=r_aQCPWHHc0
Bruce_TPU
The magnets are in two places as far as I can see.  It appears to be wrapped in duct tape sitting on a pc fan.  Actually a pc fan would be ingenious for rotation with next to no resistance. (as long as it is not plugged in! LOL)  I am not "quick" to believe, but neither am I "quick" to dismiss.
The second group of magnets appear to be on the handle opposite of the bristles.  My assumption would be that these oppose the magnets centered on the fan.  The bowl would concentrate the magnetic field from the larger magnets sitting on the fan.  Is the bowl plastic, metal or ceramic?
And Ironhead may be right.  their is either squares of metal or magnetic sheeting on the table.  Either that or a funny looking table top.
I have looked at his other attempts, and believe we should investigate further.  Sometimes the simplest design turns out to be the one that works!
BT
hartiberlin
Quote from: IronHead on April 17, 2007, 12:58:23 PM
hum
It seems he first tried out the v-shaped SMOT principle with his 2 other
videos.
The last one here shown probably has the magnets inside the crack
of the plastic bowl.
If you look closely you can see the magnets sitting at the edge of the upper
rim of the plastic bowl.
Also you can see a washer or a flat circle magnet sitting ontop the rim of the plastic bowl,
when he tries to zoom
the camera below the table.
The fan is probably only used as an axis and rotation holder for the scrubber.
The scrubber also holds magnets glued with tape to the scrubber rod.
Maybe it is no fake ?
Regards, Stefan.
