Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
Bruce_TPU
@ Darren
I could not agree with you more!   :D  If SM had not left us his posts, I would be back pumping current, seperating HHO.  There is nothing to convince.  I have an electronic partner who is helping me, hands on with my replication effort.  We have ordered the need drivers and mosfets.  Monday I start on the coil according to instructions.  Tuesday night we solder the circuits.  All while juggling family and job.  I do not expect to power my house this week with this set up, LOL, or win the OU prize.  I expect it to be a learning tool, which can then be experimented with, tuned, etc.
Oh, how is your build plans going Darren?
Cheers,
Bruce
chrisC
Darren:
Sorry, we just have to agree to disagree!
Peace
chrisC
z_p_e
Quote from: btentzer on June 11, 2007, 01:27:23 AM
Cheers,
Bruce
Precisely my point.
But since you asked, they are going quite well. No, not a GOR type at all. My own, the culmination of a year's worth of study, testing,  and contemplation of Steven Mark's material.
Rest assured, I may post it here, but only if and when I've determined without a doubt that I can demonstrate it produces more power out than I am furnishing to operate it.
Good luck with your build, at the very least, you should learn some interesting, but basic electronics through your experiments.
Regards,
Darren
chrisC
.... it produces more power out than I am furnishing to operate it.
Regards,
Darren
[/quote]
Hey Darren:
what did SM input for power? Maybe I missed it? (I only saw a swipe of a external magnet?)
chrisC
Mannix
Hi all,
Please bear with me I'm gonna give you all a bit of a gentle shake
some of you can probably see it comming...I am not being unkind.
Boy you guys seem to be looking hard for Bottom!
I though that it was as clear as xtal.....oh you want it to make sence to you, who has learned well, that this is impossible.
I tell you something that has helped me a lot I always say read it again but never really HOW!.
Read the document first thing in the morning slowly......dont try to grasp any thing .... now read it again before bed slowly...again go to sleep with it if you like ...now In the morning back to your normal speed...try to get it..
Ask any questions and look again....then you are qualified to be confused.
Guess which house  I keep all my current documents in?
One part I better answer here, the most illogical part perhaps.
The collector in the document is 1 turn of twinflex  there is another turn of twinflex underneath it 44 mm away that is reverse connected...that is where the mobius twist is made ......it is in the connection....
I know that this is not what many people have been doing and it sort of seems reverse logic...but If you ever expected some thing that made sense directly...you were always going to be disapointed.
Again I say this is a RESEARCH PROJECT...This is not a generator...go to the hardware shop!
This is so that you can see the power and decide if you can or want to  add to the knowledge....just like it has been given to you.
Otto and Ronnette have given you guys the key to the gate. The effort that was put in is even shown.an example has been set.you can watch the gate open before your eyes....wether you want to work with this is up to you. Some of you will get hurt by it...be careful but do not expect them to hold your hand all the way.
I think that this is about what YOU can bring to it rather what you can get out if it.
Good luck and thank you all for listening
Darren,
Im surprised!
The efforts that you put into the spinning magnet game was astounding  you do see some similar things with that control coil....you have so much to offer here, why do you share your doubt? Who does it serve?
Lindsay
