Ronotte's amazing TPU experiments.
Started by gn0stik, April 18, 2007, 08:27:12 PM
gn0stik
Even mine probably won't be exact, upon my first build. The control circuitry yes, but the TPU itself will be a 15" since we have most data on that.
I will try to incorporate all physical construction clues SM has given us. 245khz, and 35khz will be used.. 15" with a lamp wire collector. Maybe tubes instead of mosfets, if I can figure out how to adapt the circuit. Everything else the same. I think it would be the next logical step from where you are at.
Dave is building to your exact specs I believe to verify your results. I'm anxious to see this.
power on the collector is amazing even if it's not OU, and tells us we have something of the construction correct.
Regards all,
Rich
ronotte
Hi all,
Thanks Rich for your courtesy, it has been highly appreciated......right for next evolution.
To all: it seems that duplicating is not so easy so I'm here to ease every possible poroblems.....after tampering so long with this kind of circuitry I can say that I do know them with my eyes shutted.
Dave, I think that I will fix your setup in less time than you may think.
Today I've completed the next ring wiring & labelling and actually I'm doing some documentations, I'm almost ready to put it in operation...after the electronics circuitry completion....trying a CLOSED LOOP.
I do know in advance it will not be easy...I'm prepared.....but that's the fun part of the game I do like.
Roberto
d3adp00l
@Roberto Do you have any inkling as to how the system will become self sustaining? I understand crawl before walk, but given the time you have into this, I was just wandering about theories you might have. It would be easier on you guys if we had an idea of what kind of energy SM's unit tapped into, and yes I know that even he didn't have an idea. It would be like building a solar cell and accidentally having it in the sun.
@gn0stik I would be building one however I lask the test eq to be of much use, I have no scopes and the such.
History is full of people who out of fear,
Or ignorance, or lust for power have
destroyed knowledge of immeasurable
value which truly belongs to us all.
WE must not let it happen again.
-Carl Sagan
ronotte
Hi all,
I confirm that my new setup is almost ready. I think that today I'll begin a step by step testing.
The new setup is 90% different from the previous one (the aim were to check possibility of power extraction from a lead at 90 degrees), it does retain: the inner collector and the controrotating mag fields. The rot mag fieds will be now at a much lower frequency they will be set @ Shuman frequencies. As you see we (me & Jacob) are now targeting the SM operations.
This approach, has been proposed some time ago also by Marco (.....which posted a very good theory...) , I tried it......but did not had anything  at that time.
I do hope that this time we will succeed as now we have a complete understandable & meaningfull situation reference frame also according to Reconnection theory. As per 'closing the loop' we have many choices' : I've to test them.
As usual, after at least the first theory confirmations, I'll post here every details.
So be patience, do replicate my first design: it is really important because it will permit you, as it has been for myself, to understand what's really happening in TPU...not going on with 'shutted eyes'.
Best regards to all
Roberto
nong
@Roberto,
Today I had test TPU.  Thank you for you sharing information.
