Ronotte's amazing TPU experiments.
Started by gn0stik, April 18, 2007, 08:27:12 PM
FatBird
Is it Possible that SM used this Outer Wrap as a DELAY LINE or a MODULATOR to SMASH Frequencies together.
ChemTrails, ChemTrails, What's in your sky?
Google it.
weri812
@ twosox
that tpu drawing looks likes Rosphere
is that  what you based it on?
wer
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
polartronic
Dear Roberto,
Thank's a lot for your groundbreaking experiment !
I'm still amazed by the hundreds volts you're getting in your set up !
I'll try to replicate your first design but I have few questions about it:
  1) why do you connect the collectors to the + 15 V (is it for a kind of polarisation purpose ?) and to the rotating field coils ??
  2) where do you apply the whistler wave ?
thank's again,
PLT
ronotte
Hi PLT,
I'm glad you are trying to replicate the design.
1 - It is not clear what you mean. The connection to +15V is necessary to allow MOSFET switching and so to have the rotating mag fields.
2 - In this first design there is not a whistler coil. I'm just testing it now! Practically I've added a new rot mag set of coils resonant to whistler wave ( 30 -35 KHz). Please take in account that this new design is much different and still does not deliver expected output. So for you is better start with the initial project in order to see de-visu what happen.
Roberto
twosox
@weri812
I think it was, i can't remember now. couple of things i've noticed, if the outer coil is disconnected (put a break in it) the scope goes quiet and no combination of frequencies gives me the same as when its a closed loop. a cap across the outer coil makes the spikes bigger but smooths out the ringing between pulses.
@SUGRA, sound advice (pun intended, lol) input to the coil at 50% or less.
