Re: Marks TPU
Started by kokomoj0, April 26, 2007, 05:44:25 AM
kokomoj0
I have not built one yet but this is how I would proceed.
First I will get a 1/2" round soft steel rod and bend it in a circle.
Next get your dip meter and wind your main coil around the toroid you just made opposite the open side.  Use the right hand rule so north is clockwise, direction doesnt matter as long as it is the same as the magnet.
If you have a dip meter you can check it to see if your resonance is in a reasonable range.  If not you are stuck with guessing or wait till either I build it or someone else does.
Then pick up a nice strong Neo Mag that is also 1/2"
Next where the ends of the rod meet I will slice out a part to fit the magnet into that gap, leaving it just enough clearance so that it would  slip out if it lost all its magnetism .
The next step is to make a coil that you can pulse that will make the magnet slip out and fall out of the slot.   So using your right hand rule wind it so when energized it opposes the north pole of the magnet and another coil so it opposes the south pole of the magnet.  See the drawings.
These coils are placed on the iron toroid next to the magnet poles.  Once that is accomplished you have properly sized your commutator winding for the applied voltage you plan to use on the test run.
So one coil is the output and the other is the magnet field nullifying coil.  The output coil must have its north in the same direction as the magnets north that is in the gap.  Note the reversing voltage that you are tapping from the other coil. n Be sure the resonance or inductance is identical on both coils.
Then use the voltage from one to activate the reversing coils on the other toroid as shown in the pic.
Once the test run is done make sure you calibrate your reversing coils properly so that it nulls the magnet.  You only want to reverse the the field enough to null it nothing more.
To much will reversing will cause premature loss of magnetism and not enough reversing will cause less than full power out.
Once you get the resonances matched and everything tweaked out and working propery bend that rod just a bit so the magnet fits on the snug side and be sure to varnish the coils so they do not change the resonant frequency.
Thats how i see this little puppy working.
Cheers!
Sorry to ruin your party marks or who ever you really are :)
http://www.aaroncake.net/forum/uploaded/wasssup1990/20073171357_rene-rator_2.jpg
Sauron
giantkiller
Quote from: kokomoj0 on April 26, 2007, 05:44:25 AM
Cheers!
You have made the 3 greatest mistakes right from the 'get go'.
1:) You have not built.
2:) You have not seen the result from electrons moving in a physical test.
3:) You have mocked a fellow poster. And one, I might add, who has not yet failed in his explanations.
You have lost all credibility even before you acquired it. Virtual suicide. Noise.
--giantkiller. Fools rush in where angels dare to tread.
Dansway
@kokomoj0,
QuoteSorry to ruin your party marks or who ever you really are
What the hell?
Gzz....  Not another arm-chair boy!
Go AWAY!
~D
CTG Labs
