New accelerating gravity wheel ! Converted video from www.newenergymachine.com !
Started by hartiberlin, May 11, 2007, 12:49:03 AM
WalterSingletary
In my opinion as long as he has a system that works he is doing a humanitarian deed, And is a Genius!
It is going to be a great year!
The question I have about his design is what powers the actuator arm to move the weights to the center 12?? Maybe the air strut catches the impact and stores air pressure that can be recycled? (Just thinking aloud)   ???
dutchy1966
I think he already said before that the cylinders and springs store the impact energy to help lift the weight(s) at the 6 o'clock position.....where it is released by a lever. Seems to make sense, compress the air cylinder during rotation and release it at the right position to (help) shift the weight up by half a stroke......
Bob if you're reading this can you confirm?
thanx!!
Robert
fernando
Hi all,
I have been following what Bob has said and have tried time ago to do something similar with little means. The idea of Bob is that if you put a weight at 12:00,  it weighs A times 1. When the pendulum reaches 6:00, and depending on the lenght of the pendulum and the mass of A, with the addition of the centrifugal force plus the gravity acceleration, the energy obtained by A is A times N, which can be 4,5, or six or more times.
If you harness that excess energy gained by A,  and transmit it to weight B, that is at the opposite end pendulum of A, and presumably of same mass A at the center of the axis, where energy is collected, but at a state of idleness, or so to speak at a state of petential force of energy, since it is connected to mass A, who has collected all the cinetic energy, and gives/transmits it to the connected B mass,  you make it rocket to the end of the opposite pendulum B, receiving the energy obtained by A during its transit from 12:00 to 6:00, and carrying along mass A, which has encountered an end to its journey and ceases to continue gaining cinetic energy, stops and yields what it collected to B. Here you are initiating the whole process again though B.
It is simple but difficult to harness. From what Bob has unveiled, which is not extremely clarifying, it gives some light on how he has done it, with springs and shock absorbers that work pneumatically, that retain the energy gained and release it through trinkets positioned at the right place and moment. That is the reason for the tubes present in the pictures. I bet that they are crossed and exactly the same lenght on each side of the machine.
Since there are trinkets, stops, sliding wights, shock absorbers, springs and other friction supporting elements, if the whole device goes the way it should, we have to see how long it goes without maintenance or mechanical failure. In his video he mentioned a brake to make it turn at the right pace of revs per minute. That is another potential point of failure through friction which he has supposedly overtaken.
Anyway, if it works for a week without maintenance or little care it is a great success since it can be resized to yield much greater power and we can all start to go short on shares of oil companies.
Lets be cautiously optimistic and congratulate him if he has done it.
Happy New Year to all.
Fernando
helmut
Bob
Thanks to you for disclose it so far.
Will you sipply us a Video as well. Cant wait to see. :D
again Thanks very much.
helmut
fernando
Hi again,
What Bob says to have done is a doble pendulum with two atached weights that slide back and forth collecting the gravity plus centrifugal force to deliver its energy through the axis at which they are attached to the other mass that is rotating, to turn a wheel that will turn a generator at a given pace to obtain electricity deliverable directly without going through complicated or expensive rectifiers or other electrical conversion means. That is why he needed a certain pace of revolutions per minute, reduce friction and make the machine feasible to operate without much constant control.
The wheel obviously could go faster if it was allowed to bang on the extreme of the pendulum and transmit the energy to the other mass, should it not be attached to the first one. But, at the begining he said that the machine would destroy itself if it were left free because the energy would keep multiplying endlessly. That is pure logic.
So he needed to bring it to a pace through some means because he has only one generator tied to itself.
With a given mass and lenght of the pendulum, should the axis have different pulleys attached to it, in parallel, it could move more generators  conected to it, sequentially until it and came to a point of resistance in which the pace would harness all the possible energy that by multiplication the machine could yield, without going through the risk of a fast pace, a high amount of friction and a sure and early decay of the materials he employs to build it. Therefore a sure an early mechanical failure. Moreover, the electricity obtained would be exponentially higher.
Since he does not calculate the amount of energy obtained in order to calculate the size of the generator/s that could be attached, he has deviced his machine to operate with one at a soft pace that will keep the machine operating at a reasonable and conservative pace.
But if you let the pendulum run at its potential, this is another means of extracting all the energy that the double opposite pendulum with the two equal masses can deliver in theory.
lets hope he sends us soon a nice, clear and enlightening video of what he has done.
