water to oxygen technology
Started by FreeEnergy, May 13, 2007, 06:01:11 AM
FreeEnergy
Quote from: Kalash on July 17, 2007, 05:36:45 PM
You guys are crazy...
Alright...
So you get a small volume (little balloon) at the bottom of the ocean (I'd go with 2 balloons - one for hydrogen, one for oxygen so that you can better utilize them when they reach the top of the line...)
I'd place the conveyors inside tubes to that any gasses released by the balloons would rise inside the tube for harnessing at the surface (in some kind of complex processing plant or... whatever)
The water in the tube is going to be moving in the direction of your balloons - set up some kind of spill over waterwheel for processing of this "wasted" energy.
As the balloons rise, they will expand further as pressure decreases.
You must allow for this so the balloons don't POP.  Some kind of diaphragm would probably be best - get a bead of gas pushing the diaphragm upwards, inflating it somewhat... with an open bottom so the excess gas can flow out around the diaphragm inside the tube....
As Pressure decreases and the balloon expands, buoyancy will increase...
Assuming this is used as a means of lifting water (with buckets, or simple....ier...  the water the diaphragms displace and move upwards with their motion...) and this water being used to turn a waterwheel......
HEY! =(
I must have clicked out of the thread I intended to post this in :(
I'm gonna copy it over there... >_<
Whoops.
Sorry.
ok
