water to oxygen technology
Started by FreeEnergy, May 13, 2007, 06:01:11 AM
FreeEnergy
then is it possible to apply this technology inside a shuttle where it's placed deep inside water? we just need a little energy to produce air inside this shuttle, underwater pressure is not an issue. this system would provide plenty of kinetic energy to make this whole system self operating 24/7.
any ideas guys?
hartiberlin
You mean doing an electolysis deep under water and
use the gas to pull up a balloon or something simular
to the top of the water and use this mechanical pull
energy to drive a generator to do the electrolysis ?
At the top, just let the gas go out and let the container
fall down again due to gravity and repeat the cycle ?
Hmm, interesting idea..
If it is deep enough, I guess this could work, as the pull
energy is force x distance and if the distance is
deep enough you could make lots of energy this way...
Ifyou put 2 devices in parallel and have one balloon
pulling up, while the other is retrieved down empty,
this system could work very well...
The question is, if the energy generated is sufficient
to generate this much gas.
The deeper you go you have more hydrostatic pressure , so you
also need probably more energy to release gas from water there
under high water pressure...
or at least the gas volume would be very compressed down there..
Regards, Stefan.
FreeEnergy
the rising and falling shuttle would provide enough kinetic energy for electrolysis deep underwater :)
peace
FreeEnergy
it would be nice if someone can try this out because right now i have no $$$.
peace
FreeEnergy
what if you apply the hydrosonic pump technology to this! :)
apply this to the shuttle! :)
peace
