Controller circuit for Hilden Brandt motor needed..
Started by hartiberlin, May 19, 2007, 12:56:53 PM
JackH
Hello Honk,
Honk if you would have listen to me when I told you whate the motor was doing, the controller would have worked.  But no you had your own ideas on how the motor worked and you would not listen to me at all.  You refused to beleive that the motor was generating electricity.   So I had had enought, sending this thing back and forth across the sea was costing to much money.   Also,  I had trouble with you not beleiving me when I told you how the motor was running.
Later,,,,,,JackH
Honk
Well, if you say so, or believe this was how things turned out.
It was only in the first controller where I tried some of my own ideas.
The second one worked fine until the motor reved up to much before it broke down.
So I guess I was not to far away from the goal.....
I just wish you could have gotten the measurements somewhat earlier instead of the late end.
Then I could have seen how to design the controller perfectly for your motor. Simply a blocking diode.....
But I wish you the best luck with the OSU people that was going to build you a controller.  ;)
These smart people should design it like a breeze.
Quote from: JackH on June 14, 2008, 05:48:39 PM
Hello Honk,
Later,,,,,,JackH
Magnet Power equals Clean Power
JackH
Hello Honk,
Well OSU is not going to build the controller, They turned out to be none beleivers.   I just thought that you not beleiving what I said about the motor, you will never get it right.   I told you about the motor generating electricity early on.
Later,,,,,,JackH
gyulasun
Dear Jack,
Would you mind giving another chance to Honk?  Once a blocking diode was missing the success can be real close now?  Of course maybe Honk is still busy with his own jobs...
Wishing you Good health,
Gyula
JackH
Hello Gyula,
Well if Honk would listen to me about when I tell him about motor, but I dought it if Honk wants to continue.
Later,,,,,,JackH
