Controller circuit for Hilden Brandt motor needed..
Started by hartiberlin, May 19, 2007, 12:56:53 PM
utilitarian
Steven, it looks like you put a lot of work into that test, thanks.
I have another general question, and I am not an expert in things electrical, but this is what I am having trouble grasping.
It seems like the whole purpose of the motor is to take electricity, convert it to mechanical energy, and then convert the mechanical energy back to electricity.  That seems wasteful.  If there is something to be gained from redirecting the magnetic flux like that, can't there be a way to just harness that surplus without having to convert the electrical to mechanical and then back again?
casman1969
Hi Steven,
Let me congratulate you on a most impressive video, your systematic approach and the marvelous craftmanship of your work.
Your motor is similar to Jacks' but not a replication as your magnets are not in his position and your rotor is very different.
Please don't take this as criticism, for I admire your workmanship. Keep it up and again, congratulations.
Carl
aladinlamp
Quote from: Nali2001 on June 18, 2008, 11:35:19 AM
Hi all,
Here are the motor tests:
http://www.krystyna.nl/Machine/MotorValveTests.wmv
Let me know what you think.
Regards,
Steven
Hi do you think problem is the switching frequency? since in previous video in "steady state" the valve works as intented
LarryC
Hi Steven,
Well, Great job, Carl said it all, so I'll not run on.
I am confused about your lack of increased torque. Your magnetic switching unit is closer to the Sumo motor, you can see the performance charts here if you haven't before:
http://www.genesis-corp.co.jp/e/e401.html
There main motor is a hub motor (example at bottom of page), so the stator and rotor are inverted. But they have four magnetic switching units instead of two. That maybe where you are losing some of the torque.
Regards, Larry
casman1969
Hey Jack,
Tried to send a PM but they must be having problems.
Just wanted to say Hey and wish you all the best as you are a true Hero.
You are in my prayers.
Carl
