Controller circuit for Hilden Brandt motor needed..
Started by hartiberlin, May 19, 2007, 12:56:53 PM
wattsup
@Ergo
What would you do if you were waiting around for your patent to go through, can't really talk about your device and you have a nice workshop just waiting for you? lol
Ergo
@wattsup
I don't mind him building a lot of motors, but ever since he started building these things way back, he keeps repeating
himself in the same manners over and over. Almost every motor he had was well overunity (except the the early ones).
Then suddenly he scraps the motor or just abandon it in order to build another one. And this goes on and on.
He also contradicts himself in every other sentence about his progress. Something does not feel right about the real truth here.
I would really love to see an educated guy from this forum go down to his shop and perform accurate input vs output measurements.
He's reported 90 Watts in and 1/2 HP output on his present big motor. This is 373W / 90W = 4.14 COP. Very impressive.
He want's a controller to adapt the output from the generator into the needs of the motor & then run it for prolonged times.
That is fine with me, but at this COP level it doesn't take a controller to run the motor in closed loop if the reported COP 4.14 is true.
He just need to hook up his 150V powersupply directly to the generator output and then it should run by itself once started by external
power that is disconnected once the motor has reved up.
Let's say his 150V adjustable powersupply has an efficiency of 70%, then he still has 261 watts left for the motor to run in closed loop.
It doesnt matter that his motorcycle points burn out after 10 minutes or so. If he can show a self runner for that long he's got a winner.
This is such an easy task to perform if the COP report is true. But I'll bet my two cents on his motors not being OU after all.
JackH
Hello Ergo,
I'm building one for a car now, you jerk.   The one I built with one inch magnets was not overunity, Until I started building one out of 2"x 2"x 6" magnets they were not overunity.
Later,,,,,JackH
Ergo
Quote from: JackH on September 23, 2008, 06:23:40 PM
If your so sure of your motors being plenty overunity and try hard to prove it,
then why don't you test my suggested self runner by connecting your 150V
powersupply in closed loop to the generator?? This really pussles me!
JackH
Hello Ergo,
A Dino is the only way to tell how much HP an engine has got.     If I hooked a 150 VDC generator up to my motor, it takes around 20% of the power to pull the load the belts pull.. I would haft to gear up the motor to pull a 150 VDC generator.
This way I can just hook up a dino up to the end shaft and get a readying.
I and in any way trying to tell you what to do , but I do now that a dino is the best way to go.
Later,,,,,,JackH
