HOW to use Radio Frequency as Catalyst!!!! TPU in Water!! Patent Here-->
Started by Bruce_TPU, May 21, 2007, 11:43:05 PM
pese
Bruce_TPU
@ Pese
Thank you Pese for your kind offers of help.  I am sure there will be a need for it as well as any easy schematics for us electronic newbies.
P.S.  And the Patent you posted is the same one I started the thread with.   ;)
@ everyone
Patent's Quote:  (here we go again! LOL)
"...defined as the signal frequency determined by nuclear magnetic resonance of the selected catalyst. It is commonplace to use nuclear magnetic resonance to identify elements within a substance and the signal frequencies of various elements (including catalysts) are listed in widely published tables."
If someone with a knack for research could find these tables (charts, data sheets,?)  and post them here on this thread, that would be a good starting place.
Thank you for your time,
Bruce
Bruce_TPU
@ those interested in direct electrolysis without a metal catalyst I have this for you:
"The unit does not use "normal brute force" electrolysis when operating in high efficiency mode. It relies mainly on a chemical reaction that takes place between the electrolyte used and the metal plates, which is maintained by electrical energy applied and stimulated into higher efficiency by the application of multiple harmonic resonances which help to "tickle" the molecules apart. I coined the term "electrochemical reaction" to describe the process and I called the chamber an "electrochemical reactor". I used multiple cells in series to lower the voltage per cell and limit the current flow in order to reduce water vapor production. It relies on the large surface area of the total number of cells to get the required volume of fuel vapor output. In my first prototype of this design, I used a custom built controller/driver that gave me a lot of adjustability so I could experiment with multiple frequencies, voltages, and waveforms individually and compare performance. The result was a pattern of 3 interwoven square waves rich in harmonics that produced optimal efficiency. "
Let me guess...hmm..Resonant frequency of the plates, Harmonic and intermodulation.  He does not say, but that would be my first try!! LOL  RF signal!!  Let me reword something...I  KNOW FOR SURE that this person did this.  I can't tell you how I know at this time, I might later.  But this is TPU tech applied to water.  Trust me when I say that.  You need RF signal generator, small amount of electricity, amplifier of RF signal.  Measure the Resonant Frequency of your plates (like a speaker!) Double that for the second frequency, this is the harmonic.  COMBINE the two for the third.  input to your plates and ....  ;D
The cat is out of the bag!!  LOL
Read his story here:
http://www.freeenergynews.com/Directory/Transportation/Bob_Boyce/#Part%20II
A public thank you to my newest source for this info.!!!!
(Is anyone starting to see a pattern here besides me?  I hope so!)  ;)
Bruce
pese
dutchy1966
Hello,
Just like to react to some things said here earlier. Off course you can't replace aluminium or other materials that are being used up in a chemical reaction! They are crucial to the reaction.
The patent is about mimcing the catalyst (a catalyst that isn't being used up to be more specific).
This being said it might be possible the replace the NaOH as it is not being used up when producing Hydrogen from aluminium. As NaOH is composed of different components itself you probablt need differnt frequencies te simulate the different components?
Robert
