HOW to use Radio Frequency as Catalyst!!!! TPU in Water!! Patent Here-->
Started by Bruce_TPU, May 21, 2007, 11:43:05 PM
Bruce_TPU
http://www.freepatentsonline.com/6217712.html
Resin Rat will like this, forget the catalysts, just pick a frequency to mimic the catalyst and you have hydrogen.....!
ResinRat2
VVVEEEEERRRRRRRYYYY interesting!!! :)
This I must read. Thanks btentzer.
ResinRat2
I see hints of Stan Meyer's ghost in this one, but I'm no electronics guy. Resonance frequencies are all over the HHO threads. Is this different only because it uses RADIO wave frequencies? Somebody tell me. Does that mean it can get by with using voltage lower than the other methods that don't use catalysts?
kokomoj0
Quote from: ResinRat2 on May 22, 2007, 08:09:29 AM
yah i think so.
If i correctly understand the meyers unit stan is trying for electrical resonance where the water tank is in essense the capacitor for the electrical circuit.
This guy is looking at the resonance of the water molecule itself with the intent of easily forcing it apart using the mass as the resonant frequency.
Thats my take on it.
here take a peek at this:
http://www.youtube.com/watch?v=A7RFyh5ABcQ
this one has the best music!
http://www.youtube.com/watch?v=6uNAYUSdA-4
This one is cool too watch the modal patterns change:
http://video.google.com/videoplay?docid=-4971487472071937676&q=
How to use resonance to split water:
http://v3.espacenet.com/textdoc?DB=EPODOC&IDX=DE4238952&F=0
Received Patent-right !
But invented 1982: 2007, now free process technology !
S
  dL
