Proof of concept - perturbing a static magnetic field
Started by bob.rennips, May 30, 2007, 12:57:25 PM
0 Members and 72 Guests are viewing this topic.
bob.rennips
I'm starting a new thread dedicated to experimenting with perturbing a static magnetic field. The static magnetic field generated from either a permanent magnet or a steady DC current into a coil.
This was all started off by a posting by kames. Thanks kames. I've reproduced the posting below as I don't know how to link off to a post on another thread. I've also re-uploaded the two relevant patents as found by kames.
___________________________________________________
@All
A few pages back (page 168) I have posted a simple and stupid experiment. Doesn?t look like anybody picked it up but sorry. Anyone can reproduce it with ease. There was a purpose to post it as a prelude to something else. I was thinking about opening a separate thread but as long as most of the people are in this thread I decided to post it here. It can be moved to a separate thread at any moment. There were several events that struck me when I performed that experiment. First, nobody could give a reasonable explanation. Second, I have found two patents in my unsorted files. Those two patents were backed up just in case a long time ago, before I even started looking for SM?s tpu. When I first time read those patents I decided ?old news?. When I recently read them again having all the stuff of the tpu in mind there were a lot of things to look over again. There were a lot of things to try to understand what SM was trying to tell from his every single message through Mannix.
I am in the process of testing those two patents. That is not a manual to how to do the things. Those are basic ideas and results.
The first patent (file name) I changed to ?power unit?. The second (file name) I changed to ?control unit?.
In the power unit the text is much more important than the drawings. Read it all. Don?t miss a single line. Drawings are not the same as what text is saying.
In the control unit, the drawing might remind you what you saw in the videos. It is just a nice technical solution.
I have scanned all the attachments from this forum and didn?t find anybody ever posted it before. Maybe I missed something. In this case, just disregard this post.
If you read these patents for the first time, come back and see what I posted on page 168. Any criticism or opinion is okay except for teaching me how to use a scope or probes or asking if I forgot to check my battery charge.
Again, I haven?t tested everything from these two patents. I am in the process. If anybody can get ahead, it is only better.
Regards,
Kames.
chrisC
@bob.rennips
Thanks for your post. Yes I would agree this new thread should just concentrate on the Kames patent findings which shouldbe interesting to verify, after all the theory and setup seemed like it's long the correct path? Thanks also to Kames for his excellent search.
Interesting that a search on the USPTO Public Pair Info. database yielded nothing on the inventors nor was there any data found for the International PCT numbers. Starnge...
chrisC
bob.rennips
Looking at the following configuration for the first coil.
Note this is a proof of concept. As such it will have multiple battery power sources. The point of the experiment is to observe anomalous voltage AND current being generated, which substantially differ from the expected. IT IS NOT A REPLICATION OF THE SM TPU.
I believe the SM TPU manipulates the magnetic fields in the way this device is doing. Once I understand what is happening regarding the magnetic fields I hope to translate this to a possible toroidal arrangement of coils.
The experiment is based on an air core solenoid NOT a TOROID.
1. 1st coil using heavy gauge enamelled copper wire of say 2 layers is wrapped first. This is where I hope to meaure some anomalous output voltage and current.
2. This is followed by a couple of rounds of pvc tape for extra insulation between different coil layers.
3. Next is wrapped a bifilar coil of lighter gauge enamelled copper wire. It is into these coils will be pulsed the low voltage followed by the high voltage. (see later for parameters for these pulses).
4. This is followed by a couple of rounds of pvc tape.
5. The next coil is the coil that will generate the static magnetic field. As such it will have a 5-6 layers of enamelled copper wire. This coil will be connected via a manual switch to a 12v battery. Resisters will be added to set the current to approx. 1amp.
To start with I'm going to have have the first pulse set to 12volts and the second pulse set to 24 volts. I'll be using IRF840s to trigger the pulse and a simple logic counter to time the period between the pulses. The pulse width will be approx. 10% of the period between the pulses.
I'm starting off with very low voltages so that I can obtain a baseline of expected waveform shapes on my oscilloscope and voltage ratios for a particular frequency period. I'd be surprised to see anything anomalous with these low voltages but these observations will act as a control for later.
I'll then up the voltages to see at what voltage levels things start to happen.
DIMENSIONS OF SOLENOID
Based on the work of Bruce Cathie I'm going for the following coil dimensions.
Solenoid Inside diameter: 0.5065 inches
Solenoid Length: 3.03906 inches (3 1/32 inches)
This is worked out as follows and will only make sense to those who have read Cathie's books. It's based on geometric harmonics of the earth.
Speed of light harmonic: 144000 which is the harmonic reciprocal of 694.4444444  - the earth magnetic field harmonic. The calcs look like I'm making it up, but it follows a complex line of thought by Cathie which he's simplified into a set of rules for determining lengths that are intune - a harmonic - of key earth harmonics.
So starting with 144000:
/ 10 = 14400
x2 = 28800
Square root = 169.7056274 geofeet harmonic.
x12 = 2036.4675 geoinches harmonic.
x 6076/6000 = 2062.2627 english inches
/6 /6 /6 /6 = 1.59125214 inches circumference (base geometric harmonic for the solenoid)
/ pi = 0.5065 inches diameter for the solenoid
Assuming whole turns this ensures that the length of wire is a harmonic of the speed of light and the earth magnetic field harmonic.
The length should be a multiple of the base geometric harmonic.
Solenoid length = 1.5912 x 2 = 3.0396 inches.
In other word I'm going to get 0.5 inch diameter round piece of wood to wind the coils on with a coil length of 3 1/32 inches. I'll obviously be removing the wood once the coils have been wound so that it's an air coil.
Not sure how long this will take, family commitments etc. but will post further updates as I have them.
dutchy1966
Hi Bob
Good idea to start this new thread! As a matter of fact I was thinking about it too.
Also I'm playing with the following idea in my head:
How can we have a simple proof of concept?
My idea is to have,say, 1 meter long pvc pipe that will nicely hold some disc neos. Image the pipe upright and a stack of neos at the bottom end inside the pipe. Our two windings go around there as shown in the patent.
Now to test the strength of the field we drop another few disc neos (so they cant turn) in the top op the pipe. While the two sets of magnets will be opposing the top set will be floating in the pipe depending on the strength of the opposing magnetic fields.
when we now start pulsing our coils the top set of magnets will be pushed upwards in the pipe depending on the increasing magnetic field created at the bottom end.
If the field really increases like the patent states the top neos will probably be shooting out of the top end of the pipe.....lol   (maybe better take an even longer pipe  :D
What do you all think, might this work well?
Robert
bob.rennips
Quote from: dutchy1966 on May 30, 2007, 01:40:53 PM
Hi Bob
Robert
Well worth a go. You could perhaps also add another coil layer to your coil for the output and have this going to a 24v car bulb. Ideally the output should be the first coil to be wrapped but for experimental purposes I'm not sure it'll matter that much.
The unknown I have at the moment is what direction the anomalous magnetic field appears. Given SM has coils at right angles to each other, this is one aspect I'll be experimenting with. If the magnetic field is at right angles you won't necessarily see a change in how much your magnets jump.
However you could hang a magnet on a piece of string on the outside of the pipe which will jump what ever direction the magnetic field moves in.
