Proof of concept - perturbing a static magnetic field
Started by bob.rennips, May 30, 2007, 12:57:25 PM
brnbrade
btentzer
To begin with high big old speaker's magnet and pvc of 1/4 ".
tks
Bruce_TPU
Quote from: brnbrade on June 24, 2007, 04:41:03 PM
btentzer
To begin with high big old speaker's magnet and pvc of 1/2 ".
tks
Okay, I already have both.  1/2" pvc at what length?  Keep going..
Thanks
Bruce_TPU
Hi brnbrade,
I have my wire, 30 gauge for the "fine" wire and 22 gauge for the "medium" wire.  I had gotten 1/2" pvc, but now I see you have changed it to 1/4".  So I will look for something 1/4" to use for my air core.
I know you said 1000 turns of the fine wire, but how long is your pvc?  4"? 6"?  It will help me when I wind to know this.. :)
Okay, I found 1/4" piece of semi-rigid plastic.  That should work.  I will use a piece 6" in length.
Cheers,
Bruce
Bruce_TPU
Okay, I ended up making it 3" in length, It probably could have been half of that.
Next I wrapped the entire coil over with high heat electrical tape.
Now I will take an FM stereo clock radio and plug into the head phone jack.  From there I will measure volts out.
Next I will hook to the primary and measure.
Then place a large magnet next to it and measure.
Then place a large magnet around the entire coil and measure.
Cheers,
Bruce
bob.rennips
Quote from: btentzer on June 24, 2007, 02:19:43 PM
@ Bob.R
The Story told to me WAS of Sound waves, from a earphone placed on a wire input.  It produced massive ammounts of electricity!  The earphone was plugged into an FM radio.  All of this was BEFORE brnbrade posted last night.  he wired direct to his headphone output and did not use the same method to produce the waves.  :)
Cheers,
Bruce
You're saying the earphone was not electrically connected to device producing this large amount of electricity ?
