Chas Campbell free power motor
Started by TheOne, June 04, 2007, 10:25:17 PM
rMuD
Quote from: hartiberlin on September 07, 2007, 08:28:05 PM
Quote from: hansvonlieven on September 07, 2007, 08:15:24 PM
G'day Stefan,
You are still stuck with the basic problem and that is how to rotate the entire assembly 30 degrees to bring the next ball into play when you only have 27 degrees or less to play with and only one ball to do it with. The potential energy in the system does not change with a 3 dimensional arrangement or any other arrangement.
Incidentally zero, I am a qualified engineer, physics major at that :-)
Hans von Lieven
Then why don?t you calculate  the torque arms ?
Where is my error in my calculation ?
Here it is once again:
2 balls 0.5 distance from axis x 1 Kg = 1.0 units
2 balls 0.8 distance from axis x 1 Kg = 1.6 units
1 ball   1.0 distance from axis x 1 Kg = 1.0 units
sum= 3.6 units
On the right side we have then only for 2 x 15 degrees:
1 ball 3.8 distance from axis x 1 Kg = 3.8 units
1 ball 4.0 distance from axis x 1 Kg = 4.0 units
sum= 7.8 units
Divided by 2 cause only for 30 instead of 60 degres rotation
we still have a 3.9 versus 3.6 advantage.
sum= 7.8 units
for 2 balls to be on the 4x arm... they would both be at 15 degrees off center..  not one 15 degrees off from each other, were working with a 30 degree seperation from each other, there would be no way for 1 ball to be at 4
2 balls at 3.8 distance from axis x 1 Kg = 7.6
divide by 2  = 3.6
3.6 = 3.6
I think we wasted 5 pages for that?
hansvonlieven
G'day again
Quote from: zero on September 07, 2007, 09:16:02 PM
Also, couldnt a Smot type of one way magnetics setup also provide upwards thrust
potential?
On that one you are right zero, the system clearly needs an injection of energy from somewhere in order to function
Hans von Lieven
hartiberlin
??? 7.6 / 2= 3.8...
YOu are probably tired too..
rMuD
I have no excuse, it's only 9:30pm here  :(
Quote from: hartiberlin on September 07, 2007, 09:34:21 PM
??? 7.6 / 2= 3.8...
