Chas Campbell free power motor
Started by TheOne, June 04, 2007, 10:25:17 PM
Here it is once again with a better picture:
On the left side:
2 balls 0.5 distance from axis x 1 Kg = 1.0 units
2 balls 0.8 distance from axis x 1 Kg = 1.6 units
1 ball   1.0 distance from axis x 1 Kg = 1.0 units
sum= 3.6 units
On the right side we have then:
1 ball at 3.9 distance from the axis x 1 Kg= 3.9 units
sum= 3.9 units
We still have a 3.9 versus 3.6 advantage.
Nobody has pointed out yet the error.
Yes, and I have about 30 degrees of rotation I can use ,
when I build it right for the red ball to go down,when I have an upper and lower flat rail,
not just 26 degrees !
As the yellow ball comes up it still has speed, so it can roll forward on a flat low friction rail
with no negative incline,
so you have almost 29 to 30 degrees for propulsion of the wheel there
and still the 3.9 to 3.6 advantage, so you could lift up the next yellow ball
and have again the same picture as below and the cycle begins again...
hansvonlieven
Zero,
You have just added 3 ft of additional energy into the system. Of course it will imbalance if you add additional energy.
Hans von Lieven
Humbugger
The ball is on the wheel for only 27.7 degrees out of 30
27.7/30 = 3.6/3.9
If you wish to quibble about the rounding errors, please do so on both sides of the equation.  By yourself.
Humbugger
Quote from: Humbugger on September 09, 2007, 05:56:15 PM
27.7/30 = 3.6/3.9
I can do better !
29 degrees!
What now ???
Why is nobody doing the torque calculations ???????
Humbugger
Quote from: hartiberlin on September 09, 2007, 05:58:52 PM
27.7/30 = 3.6/3.9
I can do better !
29 degrees!
What now ???
Since we are making up numbers arbitrarily, I bid 23
