Chas Campbell free power motor
Started by TheOne, June 04, 2007, 10:25:17 PM
Joh70
"A gravity wheel that size with that much weight to turn requires bowling balls, not billiard balls."
The fact, that the wheel is much to heavy to be driven by billiard balls shows again, that it's origin use was different.
ashtweth_nihilisti
Thanks John, and greetings to most lol
The R and D is very much alive, i am taking a professional fitter and turner over to see Chas to assess how he can make his wheel materials more robust and stabilize his design, all will be revealed open sourced of cause ;). I will do my best to get others tests out of the way we have two videos to still upload, no internet at home yet we just moved house, they are not as revealing of Chas's wheel as the stuff already on the page just to let people know in advance.
@ watts up,
>@AshFirst of all thanks for all your participation in bringing us the Chas Wheel as well as the Chas Flywheel devices.
We are a non profit org and here to help you are welcome
>I know it was not easy and I am sure you felt like you had to walk across a mine-field at times due to some people here giving you a hard time.
I don't offend easily, in fact its i that usually offend, no one or thing will stop me from working non profit towards building our children a future, its the time wasting that pisses me off beware any one who does my time is very precious and busy
>Well nothing is ever lost, and I am sure what you have learned from this escapade will give you more food for thought.
it comes back to what i have known for years we need a granted research and development center
>1) A gravity wheel that size with that much weight to turn requires bowling balls, not billiard balls.
I cannot address that technically, would prefer you showing us in the lab in comparison to the actual wheel
>2) If Panacea does OU investigations in the future on behalf of overunity.com, it should do it in the most impartial manner possible and not with the open intent to mainly pursue any RV aspect.
Not agreed, the RV was used only additionally and has helped some plus can improve many areas, i see your water pump and or drill lathe and or saw isn't run in RV mode.
If it is one HP then you my friend are wasting energy ;), you are welcome to use my RV drill for your experiments, but build your own via our recommendations you will see we are not wrong. I dontr know one engineer who hasn't used an RV and not saved energy if there are those let me ttell me i will show them the way, and or the engineers i know
>The initial inventors design must take precedence before any considerations for RV or other alternatives are used. Testing and fully understanding the device, as is, is more important than playing around with it in other ways. Only once the original design is understood fully, should you consider other avenues.
we did both, so DITTO don't rag on the RV bro it will cause this young man to become defensive  ;)
>I mean why should you risk putting the RV into a checkmate situation, just to prove a point. You may wind up proving the wrong point. So be careful how you decide to promote RV.
We would of never associated the RV with his device unless test were conclusive but thanks for the advice mate any ways okay :) i know you mean well
>3) On the Fylwheel generator, if Chas added two more pulleys before the generator end, he will be one step ahead of me because in Jan-Feb 2008, I will be trying out my Alternative #2 (3-6-9) located at;
http://www.overunity.com/index.php/topic,3260.msg48499.html#msg48499
Well dam man, some one building and not bitching  ??? :o :-X
Let me know if i can help i bet i can
>By using a higher than required RPM drive that will go down to its required RPM under load and a 10kw generator running at 50%-75% recovery. That should be a good mix. So the clock is ticking, tic-toc, tic-toc. And time will tell.
FREQ drive your RV with the pulley to get the desired RPM, it will help based on lab tests of loading the RV prime mover,, don't de construct your set up till we or you  get you a Freq drive for your RV.
The users ignored know why they are ignored.
Will report the results when in.
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
ashtweth_nihilisti
Ooops sorry guys missed some posts and have addressed them in my edited post.
sorry about that. :P
ashtweth_nihilisti
Chas write up updated from our on line university, his web page is being updated ATM too.
http://www.panaceauniversity.org/D21.pdf
More[tests] to come .
Ashtweth
linda933
??It is not clear if the irregular drive which makes this system work so well is due to the way that the mains motor works, or to slight slippage in the drive belts.  The bottom line is that Chas? system produces excess energy??  p16 of 18
I thought everything I had read here and in the other Chas thread and seen on the testing video clearly showed no excess energy!  I even read a couple posts where Ashtweth Nihilisti explained how he was removing the claims of excess energy or OU from his Panacea website in regard to this machine.  Now the newly-edited Panacea University booklet contains this pair of statements?  Weird!
Linda Damiani
