Another magnet only accelerator wheel design on youtube
Started by hartiberlin, June 11, 2007, 01:22:47 AM
hartiberlin
Bruce_TPU
Thank you Stefan,
That is EXACTLY what I am talking about.  An entirely new mindset concerning full rotation, using diamagnetic metal and magnets, using Lorentz Law.
Cheers,
Bruce
CLaNZeR
Dunno about this.
I have manged to get the same effect with two magnets in attraction and it gets out of the sticky point from the pull in, but as soon as you start adding more stator or rotor magnets it struggles to get out.
Even though the magnet travelled a fair way, it did like it was starting to come back on itself. Either that or the wheel was not on a level surface.
Good experiment though.
Find attached a Video showing a wheel with a magnet from a Hard Drive that has the MUMetal shield on it. This gives the same effect, but as soon as you add more Rotor magnets it comes to as halt.
http://www.overunity.org.uk
Onevoice
Hi Cla,
Rather than adding more rotor magnets, have you tried adding more stator positions? It seams like if you can get 90 degrees out of your setup, you should be able to add 3 more stator magnets and go all of the way around.
quote: The needs of the one outweigh the needs of the many - Capt. James T. Kirk
CLaNZeR
Quote from: Onevoice on June 15, 2007, 04:35:19 PM
Hi Cla,
Hi Onevoice
Yep have tried leaving 1 rotor magnet and using extra stator magnets but the same happens.
The only way around it I see is maybe increasing the wheel size so the extra magnets either on Rotor or Stator do not interfere with each other or using multi wheels stacked on the same shaft with a big enough gap between wheels so individual magnets do not interfere with each other and stagger each magnet on each wheel.
Yet another experiment to add to the never ending list LOL :)
Sean.
