Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
BEP
Quote from: electric777 on February 28, 2010, 12:34:10 PM
Awesome!!
Has anyone tried replicating the Chauncy Britten "Atmospheric Electrical Generator"  ?
http://www.rexresearch.com/feg/britten.htm
Most interested in devices which do not have any moving parts: Tesla Magnifying Transmitter, Peter Markovich's ATREE, Lester Hindershot Reciprocative Oscillating Coils, etc...
Thank you,
electric777
Thanks. If you do a search on this site you should find multiple threads for each one of those.
@sparks
I'm korn-fused. Let me know what you have for medications so I can take some and catch up with your thoughts  :D
You left me in your dust again!
Frederic2k1
@ Macmep
Is that a working TPU unit ?
Sorry I'm not able to understand russian language.
sincerely
Macmep_L
Quote from: Frederic2k1 on February 28, 2010, 06:15:45 PM
@ Macmep
sincerely
That is not TPU, just 3-F generator, but like says that guy it is generating 10 minutes after power OF.
But when we ask him to make a pic, he says, he can't because high level snow lock his garage door :) it seems like fraud. :)
He wrote an absolutely different information at different forums.
In the three-phase generator on pic beloy, if you make the imposition of the phases, it is possible to get DC, but I don't saw that someone did it successfully. This is one of such schemes, but this is not the scheme of TPU.
giantkiller
Quote from: wings on March 01, 2010, 07:18:19 AM
http://www.youtube.com/watch?v=Opb0LvX7jZY&feature=player_embedded
Two things:
The ring configuration is in the vein of the ECD and the scope shot shows major promise. The ringing shows up symmetrically in the on time. But the off time has a higher peak to peak and faster oscillations. This is most important! The self oscillation start is in the off time. His scope shots show the same pattern I started with. The next test is to reduce the on time or change the on time to 25%. His signals are 75%/25%. You want the off time oscillations to overlap the back end of the on time ringing. In other words 'The two sets of waves will overlap'. ;) Then you see the consecutive spikes building. We push the swing at the correct time...
The constant DC at the back end of the on time stabilizes the polarity of the electron torque. All is quiet. This stops the oscillatory function. Then the off transistion has to start up again only to lose any reverberation that might happen. The reverb or echo is necessary to start an acoustic or wave tidal imposition. This whole process uses the established wave content or standing wave as a bias or stored energy. That is the constant resource that resonance supplies.
Here is what I have seen: The coil produces intense noise in the off time. If the duty cycle is lowered the next check is to see where the off time oscillatory function stops along the off time window. If it stops short of the impending on time occurance then 2 things have to occur. Change the input frequency or the coil winding/configuration. Sm stated he 'snipped wires'. This can happen in alot of ways and do alot of things.
Now the unfortunate news:
This is the feedback process that is like a teseract in a house of mirrors. You change one parameter then go to another part of the configuration and adjust something else. It could be electrical or mechanical. That is the nature of the beast. I got to this point and the next step is to work the power output stage. In other words: Once you have established the echo you then need a target. Whoa!
Previous efforts have attempted to drive a coil to get power. This is basic transformer action and will not work. Doesn't matter if you use square, sine, or spark gaps. Just because you step on the gas doesn't mean you'll make it around the corner faster. >:(
http://amasci.com/freenrg/a-vectFE.html
http://amasci.com/tesla/tesceive.html
