Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
WaveWatcher
Argh! Supposedly I have an IQ that scares folks but that doesn't mean I'm not stupid.
:-X
gn0stik
Quote from: WaveWatcher on June 20, 2007, 11:59:28 PM
:-X
double negative. Man you're on a roll.  ;D
bob.rennips
I simulated Otto's circuit in the falstad circuit simulator app. Given the ANDed nature of the FETS, I used only one FET input.
Interesting that it came up that in ideal circumstances that the output should be 2.2 kv very sharp spikes and yes that is Kilo volts!!
Note that the sim. assumes standard transformers not air coils. Also to get this output I needed to put a small inductance rather than pure resistance across the output. This I think is fair as a standard bulb will have some inductance.
Increase this inductance and you get massive spikes.
Word of warning. This could EASILY be a simulator artifact. After all the nature of the circuit is very unusual. BUT I find it more than interesting that it simulated an ideal output of large high voltage spikes. Both high rise times and high voltage are known features of an SM devices.
Playing around with the values can easily move the circuit into infinite uncalculatable status from the simulator's perspective.
To use:
1. Goto http://www.falstad.com/circuit/
2. Open the attached text file and copy the contents.
3. Paste into the IMPORT section of the circuit simulator applet.
YOU MUST PRESS THE RESET BUTTON AFTER IMPORTING.
Cheers, Bob.
Bruce_TPU
@ Bob R.
HELP...please verify!!!
I did an edit of somethings:
3.5 volts input
Square Wave
7.23 Hz         <------ I have said this frequency is in the TPU because of the clues!!
OUTPUT
30.36 KV
What do I say, I am speechless!
kokomoj0
Quote from: btentzer on June 21, 2007, 01:53:59 AM
@ Bob R.
3.5 volts input
Square Wave
OUTPUT
30.36 KV
so you put 3.5 volts in at 7 htz and got 30,000 volts out?
What was the input current and the output current?
