Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
0 Members and 29 Guests are viewing this topic.
Here is a first movie of Roberto,
just showing his measurement TPU-ECD setup.
Not yet lighting the bulb:
http://www.megaupload.com/?d=SIL3B8KL
z_p_e
Before moving on to Roberto's suggested test with the simulation, I wanted to see what the current circuit looked like by scoping only the "ZERO" terminal.
F1 was 55kHz as before. See below for scopeshot.
Darren
z_p_e
I've now run the test Roberto requested.
One CC only, switched by 55kHz and 60kHz simultaneously.
Output is taken off the ZERO terminal.
Roberto, not sure if this is what you were expecting, but it doesn't look too unusual.
Darren
otto
Hello all,
@Roberto
well done. Have you tried to connect another control coil?? I think not because you cant do it!!!
Im working now on a 15" TPU. I made new collectors for this TPU.
When I pulse this "TPU", the bulb is shining very nice but the problem is to connect other controls because it CAN NOT be done.
My newest crazy idea is to make 3 Mobius for 3 frequencies and on each Mobius is on the 15" ring a control coil. In this way I have 3 outputs and then I want to pulse them with the needed frequencies. I dont know what will happen but as I already made the collectors its only a few minutes work to connect everything.
Otto
Bruce_TPU
Hello Otto,
Just a quick question.  I read earlier that you added another secondary coil, and used this through induction to light the 100 watt bulb.
Have you tried doing the identical same thing with the other two control coils, and then take these three addtional secondaries and tie them together either in series, or parallel or both for a combined output?
Thank you,
Bruce
