Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
0 Members and 215 Guests are viewing this topic.
Bruce_TPU
Quote from: bob.rennips on June 30, 2007, 11:30:45 PM
Due to time zones 'tonight' can be hard to determine. How many hours from now approx. will that be ?
@ Bob R.
No, not Earl.  And I do not know what time zone this person is in, so that is a good question!  LOL
I enjoy your experiments very much!  Theory only gives direction until proven true/false and that is what experiments are all about.
I am glad that you did what BEP suggested with the diodes on the bifilar.  I was wondering what would happen...
Bob, how can this test ALSO be conducted on the ECD??  This so fits into TAO's statement that SM so approved of.  I am just so excited because piece by little piece we are going to make this happen.  His TPU is (easy, think diode, signal pulses) but it's complexity, very deep.
Happy, Happy Days!
Bruce  :)
Bruce_TPU
Listen up guys!
I have been asked to post the pictures and details for them.  When I receive them in my mail, I will start a new thread with the information.  Here is hoping all is accurate...;)
Happy, Happy Days! :)
Bruce
bob.rennips
Quote from: btentzer on June 30, 2007, 11:40:45 PM
@ Bob R.
Bruce  :)
NO. NO. This is not what BEP was describing with his 'infinity inductor' and bifilar coil stuff. Reread my thread!!
BEP was talking about using diodes to transfer energy out of a tank (resonating) circuit. I'm doing exactly the opposite. You don't want the oscillations. You don't want a tank circuit where the energy is being stored - oscillations deplete energy. You want only an electric field. An electric field, in this set up, stored in a coil has the potential rising from 12V at one end to 300V+ at the other.
You have to keep the energy IN. The diodes are not there to bleed energy out of a tank as BEP was suggesting. You have to use two diodes one on each end of the coil so that the BEMF cannot get out. If you use one, you do not get this affect, the energy dissapates.
I've already managed to get rid of the 10% oscillations. I can now bang the voltage straight up to 300V. This is pure changing of electric field.
We need to thanks MACEDONIA for putting me onto this route.
z_p_e
Quote from: btentzer on June 30, 2007, 11:26:49 PM
Hey guys,
Just a heads up... An OU claim is coming tonight.  It is a "type" of TPU is all I can say.  They will tell you all about it and post pictures.  Just please do not overwhelm or bombard this person.  But stay tuned, it could be a very exciting night!
Happy, Happy Days!   ;D
Bruce
Bruce, If your friend has done his homework and due diligence, there will be no need for a barrage of questioning.
However, I would advise that they be well-prepared to be eaten alive if they have not. There have been too many IDI's already, and the troops are restless and may be unkind.
Darren
bob.rennips
Happy, Happy Days!
Bruce  :)
Any coil that participates in holding the electric field has to be open circuit or it has to be adding energy into the coil - all with two serial diodes per coil. As soon as any coil that is participating in holding the energy is shorted, the energy is transferred to that coil.
****For example, I have a coil and another coil wrapped at 90 degrees to this coil. If you pulse and capture the BEMF as an electric field in one coil, as soon as you short the 90 degree coil, this BEMF energy appears in the 90 degree coil.**** EDIT: This original statement is INCORRECT. Subsequent tests have shown that shorting a 90 degree coil does not affect the stored energy. The statement does apply to a bifilar coil.
The electric field can be measured on the 90 degree coil (collector) when the main coil is storing the pulse.
END_EDIT.
The main concept is to rise the stored capacitance to as large a level as possible whilst at the same time moving this electric field in a circle. I'm getting some very interesting effects when the high voltage oscillations appear on top of the already stored electric field!! This has echoes of the Italian Device.
