pulse motor Working video and info
Started by adam flow nemo, June 15, 2007, 02:03:22 PM
Ren
just figured it out mate. I was wrong correct measurements are above. I removed one of the microswitches plugs and hooked it to the multimeter and hooked the other alligator clip back to the switch. Makes sense, your measuring the current that runs THROUGH the wires yes? Oh and thats with the wall adaptor plug. I imagine it is alot higher with the battery connected.
Nastrand2000
Nastrand2000
Yah, with the transformers that plug into the wall you can suck too much current thru them which causes them to short out in the windings. if it is rated a 1 amp and you pull 2 amp for too long, goodbye transformer.
Jason
Nastrand2000
Have a good night guys....Im out....gotta take the little ones to school in the morning.
Jason
Ren
Thanks Jase, ave a good un.
I'll make a little vid tomorrow to compare amps at switch and output.
