Bird on a wire
Started by WaveWatcher, June 21, 2007, 02:46:37 PM
Bruce_TPU
@ Everyone
Yep, Special Relativity.  SM said it, and I said it here:
http://www.overunity.com/index.php?topic=2300.msg33080;topicseen
Reply #146
http://www.overunity.com/index.php/topic,2535.msg35202.html
Reply #145
But not nearly as well as WaveWatcher has just said it.  He has done it, experienced it and now posted it.  We need to wake up....this is a double from our walk to first to third, to use a Mannix analogy.
BUT what I did not think about was the frequencies opposing one another.  I had talked about AC opposing DC.  I had talked about the frequencies going in different directions, but each in it's own wire.
So to produce power, you are inputing -7 -4 -1 harmonics, but putting the same signal opposing each other in the same coil?!!  VERY INGENIOUS...
LISTEN UP EVERYONE:
This is how to grow our "baby" TPU to "teen years"!!  Does everyone get it?? :)
@WaveWatcher
Thank you, my friend.  You have saved us a great deal of time and R&D.
Warm Regards,
Bruce
Grumpy
RMF will cause time dilation, and inertia effects.   Directions of rotation will add or substract - so is directional.
        -Frank Edwards
ring_theory
@wavewatcher
No I am not a bird on a wire.  ;D Is our concept of time even right? We base the passage of time on our planets rotation and cycles. Had we been on mars would we percieve times passage as different than we currently do? so this brings us to another question. Is there a universal non-local frequency of time passage? I often wonder if Einsteins prediction that mass cannot exceed the speed of light is wrong. the equation of E=mc2 is erronious. mass was not involved in the experiment. it was an observation of light ::)
I think we will find that the speed of light is just another benchmark, like the speed of sound and much like sound with it's sonic boom. Light will have a relative effect, it will be mearly a bright plasmic glow in a full spectrum. talk about "unexpected RF burns" Best to be prepaired for that.. However the benchmark for time will be a more extreme frequency of change. Anyways the two benchmarks we will find are very different and only related through the means of achieving both.
A gyroscope with no moving parts LOL ::) Could that be why it is allways messing up on you? I can take it a step or two farther with opposing rings of a different nature.
Motorcoach1
@ Wave Watcher: You sound like one of my old friend at International prototype in Fla. If these guys get this thing assembled and start running it and it blows hahahah and that will happen! as mine did...  hahahaha The Gooberment guys are going to bee pissed.  Now i can use real Knives and Forks when i eat.  now Joe Dirt knows why i pulled my post untill i could make it safer to test.  Thanks Mike  PS guys don't test this anywhere you value it has bad side affects hahahahah go for it !
