Bird on a wire
Started by WaveWatcher, June 21, 2007, 02:46:37 PM
WaveWatcher
A few days ago my daughter asked me why I spend so much time and energy playing with my toys.
All I accomplish is swamping signal reception and damaging my precious equipment.
I was busy treating myself for unexpedted RF burns from a device that shouldn't have an output.
Even though she has a more solid background in classical sciences I couldn?t think of a way to explain where she would understand.
A moment passed and outside a bird suddenly perched on a high-tension wire just outside my ?toy? shed.
I hated to do it to her since this would be a classic response from someone thinking he knows to someone he thought could not understand. I asked her a question.
Do you think that bird has any idea that he is so near death? If he made contact with two wires he would disappear in a puff of smoking feathers.
Her response was ? No. Why should he? All that matters is food, water, his nest and propagating the species.?
My answer was ?Exactly! If that bird had a need for energy of a kind that could not be produced by eating alone he could benefit from the knowledge that the difference between the wires was key.
She said, it still wouldn?t happen as all the bird knows now is what it has been taught and the meager experiences it has. The other wire doesn?t matter to it.
Are you a bird on a wire?
Grumpy
"despite all my rage, I am still just a rat in a cage"
        -Frank Edwards
WaveWatcher
Grumpy,
I feel that as well.
I tell the wife I made a white object look pink without touching it and all she wanted to say was 'Have you checked the tires on the car lately? They need replacement.'
That was a real coversation with my kid. They all think I'm nuts and wish I would stop interfering with their radio and TV reception and just go to bed at a reasonable time.
At the time I wasn't even thinking of Tesla references to 'Bird on a wire'.
Moab
Quote from: Grumpy on June 21, 2007, 03:53:17 PM
Megga Ditto Grumpy & WaveWatcher.   Same here.
WaveWatcher
Believe it or not I did work for the NSA.
My job was to find solutions for all types of problems that others could not understand.
All of us a a weird air about us. I sense that same air from SM info.
We were taught to think in symbology not in numbers.
Everything he says is symbolic and cryptic but it appears it should be taken symbolicaly.
Two separate currents travelling opposite directs in circular path on the same wire.
The path being shorter in one direction (Mobius interconnect between two coils) than the other.
The path infinetely long (Mobius again).
Tubes (coaxial).
Little electron subjects picking up party hungry electrons to join the fun along the way.
When I was a kid there was a test performed to test Einstein's Theory of Relativity. Three identical, sealed and perfectly syncronized cesium based clocks, one stayed in the lab the other two took separate journeys around the world by flight.
The first journey the two went the same direction around the globe. There was a noticable shift between all three but it was chalked up to some environmental effect.
The second set of journeys took the two equal distances around the globe but in opposite directions. The difference in syncronization was huge after landing. One clock was ahead of the lab clock the other was behind. I don't remember the details but it was deemed proof of the theory since the math followed it.
There is one formula linking all relativity (was it called the ghost formula?) that could not be defined or explained but it is accepted simply because 'it solves'. If that formula is actually a representation of how the speed of light changes from the viewer's perspective of time then it would still solve but it would cause a firestorm in almost all physic's subdiciplines.
The difference between potentials is the place where work can be done. If the same frequency is applied to both rings going both directions with separate signals and the rings are inductively coupled to propogate that signal back and forth between rings a multitude of spawned frequencies would emerge. Each taking the same path and spawning more of the same until the mechanics of the process could not support higher frequencies without serious attenuation.
This is used in GPS today. What is it called? Saganac or Sagnac effect?
The same is used in coaxial gyroscopes. (No moving parts)
This would explain overheating, reactive load problems, upside down failures, kick starts with refrigerator magnets and why I can't control my own device!
