The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
0 Members and 35 Guests are viewing this topic.
brnbrade
jacob
And no magnet either it seems...
Does the oscillation eventually dies out (when the capacitor is fully discharged) or does it continues to run? On the second picture, the voltage looks very low, so I guess it is on its way to depletion.
Jacob
Bruce_TPU
Quote from: jacob on July 02, 2007, 07:34:59 PM
Jacob
Good point about the magnet.  Perhaps it was charged up  then the Magnet removed?
I would think the magnet would be needed?
Charging a capacitor and putting it on a voltmeter is not as impressive as lighting a 60 Watt bulb with two AA batteries, with all wires to be seen.
I wonder if bringing the magnet back will increase voltage.
Happy Days!  :)
Bruce
hartiberlin
brnbrade just send me this email:
"Hi Stefan
Yes, a i from Brasil.
My email has problems with the provider
I don't want to create problems in the forum.
If it is causing problems I leave.
I don't want to deceive. My pictures is good resolution and no  frauds.
regards"
I answered via automatic translation from babelfish.altavista.com:
Hi brnbrade, permanece por favor em nosso forum. N?o h? nenhum problema que seu email n?o est? trabalhando! Satisfa?a assim o borne mais retratos e se voc? puder satisfazer uns retratos mais elevados da defini??o do borne e tamb?m afixar mais explana??es em sua l?ngua portuguese. Muitos agradecimentos adiantado para estes dispositivos maravilhosos! Considera??o, Stefan.
Hi brnbrade,
please stay, no problem that your email is not working !
So please post more pictures and if you can please post higher
resolution pictures and also post more explanations in your native
portuguese language.
Many thanks in advance for these wonderful devices !
Regards, Stefan.
Hi o brnbrade, permanece por favor em nosso forum. N?o h? nenhum problema que seu email n?o est? trabalhando! Satisfa?a assim o borne mais retratos e se voc? puder satisfazer uns retratos mais elevados da defini??o do borne e tamb?m afixar mais explana??es em sua l?ngua portuguese. Muitos agradecimentos adiantado para estes dispositivos maravilhosos! Considera??o, Stefan.
Doug56
@All
Brnbrade answered some questions. He asked for patience, because he wants make more tests and this goes to delay between one to two weeks. After this, he will post the circuit.
About output voltage/amperage: The voltage is in picture, but he does not know how many output amperage because he dont have instruments to measure this current.
About sound connection: Stereo connection from amplifier. (he dont give more details)
He is trying several setups to improve the performance of its device.
He say that secret is booting the device :) Be patience.
Regards,
Doug
