The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
TheOne
Quote from: Jdo300 on July 02, 2007, 01:01:06 AM
Hello Brnbrade,
Nice pictures of your light bulb! It looks like you may be onto something here! I am excited about this as everyone else here is, but there is one thing I wanted to know about the sound input. I may have missed the earlier posts referring to it, but what are you using for the sound input? Is it coming from something like a sound card on your computer or an audio amplifier? We must also take into consideration the power supplied by the sound input as we all know you can have amplifiers that can output anything from 6W to 400W+ easily depending on the type. (The average sound card outputs between 1W to 5W on the speaker jack; Ref: http://www.pcmech.com/show/multimedia/160/).
I'm also interested in knowing what you are using a MOSFET for in your setup.
God Bless,
Jason O
As far as I understand he only use 2 aa input battery (3volts), not using any input from a soundcard
Bruce_TPU
Hello Brnbrade,
God Bless,
Jason O
@ Jason and All
I asked brnbrade the same question and this was his answer:
Was it a stereo head phone jack you hooked to?
It was in the exit of the I radio. Probably him already this covered with earth and it turns off automatically when has return voltage.
The volume was 30% of 100%.
More thinks that is irrelevant, because a small charge for the battery work.
If so, where  did you wire the ground of each channel?
No grounded
Cheers,
Bruce   (In the picture the jumper cable looking things are to the radio, according to earlier pictures.)
BEP
Please note that even with the ground not connected a stereo signal from almost any device - the circuit will be complete when the audio signal phase difference is not zero.
This does not mean failure. It just means it is possible the wattage from two channels may be additive sometimes.
However, if it is coming from the headphone jack and not the speaker connection the power is much less than the rating of the amplifier.
GREAT WORK either way!
Jdo300
Hi Bruce,
Glad to hear that his sound inputs to the coils are not grounded. Thats consistent with all of my one-wire experiments, like the one I posted on YouTube: http://www.youtube.com/watch?v=XpEYlmsMmyw
I'm still not completely satisfied about the info for the sound input. It's good to know that he is using a radio but I want to know if he is inputing the signals from an earphone jack or not. Knowing what kind of radio he has would clear this all up for me. If it's a small radio, then I'm guessing the earphone jack, but a larger one may have outputs to connect external speakers, in which case the power input could be much higher.
God Bless,
Jason O
Earl
Hi All,
the bulb Brnbrade is using is a standard H4 halogen bulb.
From the Net:
The H4 was the world's first 2-filament halogen automotive bulb. It was introduced in Europe in 1971, and was used in many millions of European and Japanese headlamps starting in that year, but wasn't legalized in the US (where it was designated HB2 or 9003) until over two decades later, in 1992!
    *  60/55W Ultra High Output Plus 50 (Narva Rangepower+50*): $19/ea
    * 60/55W Narva Rangepower High Output Plus 30: $13/ea
    * 70/65W Osram Plus 50: $22/ea
    * 85/80W Osram Plus 50: $24/ea
    * 100/55W Narva: $17/ea
    * 100/90W Narva: $20/ea
    * 130/100W Narva: $22/ea
About H4 +50 Bulb Brands:
The H4 +50 bulbs from the big four reputable European bulb makers (Philips VisionPlus, Osram SilverStar, Narva RangePower+50, Tungsram Megalicht) are functionally identical. When we pick ten samples of each and put each one through photometric, optical comparator and life tests, there's a very narrow range of performance and life differences, and those differences are randomized among the four brands.
The one Wattage level is for low beam, the other for high beam, which sits behind a small piece of metal to give a sharp optical cutoff in order to reduce blinding of other drivers.
I would think Brnbrade is using the standard 55/60 Watt bulb.
Regards, Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
