The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
TheOne
if you are getting 2 volts you cannot connect on LED on the circuit and at least see the light!
@wattsup,
what is the time deflection saying ?
How many millisec or mikroseconds per div ?
Can you sync the scope to the waveform ?
Hmm, do you have a friend who knows better how to use a scope ?
You need to set the scope onto DC input and set the sync to
your input channel and choose the right trigger threshold voltage
level, so it always triggers at the same input voltage level.
Please set the amplifier settings a bit lower, so you have 0.5 Volts / div
Then the amplitude will be bigger on the scope and the sync circuit inside the scope
works better too.
Maybe if you get a stable picture, then take a new screenshot please.
Otherwise , can you compare the waveform with a pure 50 or 60 Hz Waveform
from the AC grid ?
Does it have the same frequency as the output from your coil device ?
The question is, if your device just picks up any AC grid radiation from
a nearby transformer, maybe from your halogen lamp on your table
and induces it into your coils ?
Thanks.
pese
brnbrade
MeggerMan
@Wattsup,
I think you are seeing 50/60Hz mains noise.
I saw this on my setup.
It is most noticeable when you touch the copper end of one the coils with your finger.
Rob
