The Brnbrade Coil/Overunity?
Started by Bruce_TPU, July 01, 2007, 12:14:40 AM
Doug56
@ EMdevices
QuoteBrnbrade says:
Eu postei todas as informa??es necess?rias aqui.
N?o importa se foi colado com massa de modelar (Chiclete).
O importante ? que o meu dispositivo funcionou.
N?o tem nenhum "ingrediente secreto". Eu s? furei a bolha. O aether ? maravilhoso.
Translation:
I posted all the necessary informations here. It does not matter if it glued with modelling mass or bubble gum. The important point is that my device WORKS. It does not have any "secret ingredient". I only pierced the bubble. Aether is wonderful.
Note: "funcionou" or "funcionar" in portuguese means "works" or "perform".
@ wattsup
QuoteHi wattsup
O que estou fazendo aqui ? mini vortex dentro dos rolos de cozinheiro.
Pode parecer piada para alguns, mas ? exatamente o que todos aqui est?o
procurando.
O modo que voc?s est?o fazendo ?: trocar campo magn?tico em transformadores mobius.
O al?minio no meu dispositivo tem uma fun??o importante. N?o ? somente isolador do dipositivo.
Ci?ncia do vortex diz, elemento est?tico forte, anula campo magn?tico e cria vortex driver.
Hi wattsup
What I have making here is mini Vortex inside of the cook coils.
It can seem joke for some, but it is exactly what all are looking for.
The way that you is making is: to change magnetic field in mobius transformer.
The aluminum in my device has an important function. It is not only devices insulator.
Vortex Science says, strong static element, cancel magnetic field and creates driver Vortex.
@All
I personally believe in Brnbrade. I think that his device works, but we dont to obligate Brnbrade disclose WHAT he discover. He have this rights. Think guys, think!
Doug
EMdevices
thanks Doug,  that would be a better translation.   So it "works"  that's great.  Let's hope that means  Over Unity   :)
I want to believe !!!    Ha  Ha  Ha  :)
EM
Doug56
Quote from: EMdevices on July 11, 2007, 05:34:52 PM
Hmmmm.... Maybe!
Doug
jacob
Quote from: chrisC on July 11, 2007, 03:36:56 PM
@wattsup
Thanks for the posting. I believe Brnbrade has discovered some anomaly which he is trying to further experiment. No one in their right mind will spent this amount of time trying to hold up a deceit. Like Otto suggested, it may be structure orientation & spacing issue specific to these coils. I'll give him room and space and afford him some courtesy.
chrisC
@ Rich, EM, Darren, Wattsup
Thank you for your constructive comments. I had a change of heart.
@ ChrisC
You're right. Brnbrade has discovered some anomaly. And specific structure & spacing issues are important. Which is why I mentionned earlier that building such a device requires a lot of precision (which, by the way, I'm sure Brnbade is capable of).
And yes, let's give him room and space and afford him some courtesy. He will join in whenever he feels like it.
In the meantime however, experimentation must go on. So let's look at the facts...
The fact is that aluminium is an electrical conductor, but it is not magnetic. That is to say that it allow the concentration of electrical charges inside a magnetic field without interfering with its path like a magnetic substance would.
Now if we look at Brnbade coil's layer structure:
Core -> insulating -> aluminium -> insulating -> fine wire coil -> insulating -> aluminium -> insulating -> Thick wire -> insulating
It's clear that we have 2, back to back, concentric capacitors here. And since these capacitors are incorporated into the coils, this is a great tank circuit to experiment with, because its capacitance and inductance elements are not only coupled externally, but also internally. Which mean that we have electric and magnetic fields in direct interaction  within the context of a resonant circuit.
But to take full advantage of the aluminium within the device, it must be connected electrically to the coils. It must be part of the circuit.
Already, initial tests have shown, without connecting the aluminium, that there is a steady voltage increase that builds up across the interconnected coils with only a magnet to start the process. Some have speculated that this is being picked up from the grid. Maybe... Then maybe not... The fact is that there is "something", and it comes from somewhere. Also, let's not forget that there was not much grid to tune into back in 1871, yet... So it would be best to be sure about where this "something" comes from.
But wherever the power comes from, the fact is this tank circuit oscillates for free. So if we tune this device to a frequency relevant to our purpose, we can achieve such purpose without the use of an external energy source.
So, even without the aluminium being connected, this circuit is already worthy of all our attention. Now, what happens when the aluminium is connected?
Jacob
EMdevices
you know what I was thinking.
we can also experiment with the other interconnections.
Basicaly, if we imagine the flux from one rod entering the other , and represent the polarity of each coil with "A"  , when it aides the flux, or with "B" when it does not.  we can have a number of possibilities for interconnecting.
A1 to B2,  B1 to A2
A1 to A2,  B1 to B2,
etc..
EM
