ENYBODY TO HELP
Started by MACEDONIA CD, July 02, 2007, 05:11:48 PM
MACEDONIA CD
HI  I WHAT MATEMATICAL HELP
I WHANT  TO MAKE  3 TESLA ENERGY ELK. MAG FORCE  WHIT  9 VOLTS  AND  0,2 MILIAMPER
WHIT  THIS FORMULA
                                              N
                                 H= I x --------       I - IS  AMPERS
                                              L             N- IS  NUBERS  OF TURNS
                                                            L-  IS LENGH OF COIL
                                                            H-   MUST BE  3 TESLA  FORCE
   MUST BE USE   ONLY  9 VOLTS  WHIT 0,2  MILIAMPERS     to created   3 tesla force elk .mag   if you have  eny  matematical  help    to make  how many turns  and how many leingh  must be  a coil
important  is  this  coil  not be put  in the any core
this coil  is whitout core     thank  for  all
   by from macedonia
Bruce_TPU
Yep, I want to make a Tesla electromagnet as well at 7.3 Hz to provide the ECD with a stationary wave.
It will take a circuit to do it, my Macedonian friend.  And when the person working on mine finishes (hint, hint :) )  I will post it for anyone else who would like to experiment with it.
Happy Days!  :)
Bruce
duff
