EMdevices' TPU with batteries in it
Started by EMdevices, July 15, 2007, 10:33:13 AM
Gregi
I think you are right Carl, calling it a hoax would already imply that we know exactly how he did it and how it works.
So I modified the title, to be as factual as possible.
Sorry for having rushed with this judgment.
Personally, I still think the TPU is real and I am not discouraged by EMdevices' revelation. I understand that he got fed up with it and it was a way to release some pressure.
Regards,
Greg
Super God
I guess I really couldn't follow your post very well, Lindsay.  Oh well.  The TPU is real, I believe it is, the open TPU was pretty convincing I must say.  We're so close to making one of these that...well, I dunno.  But, we're close.
-Brian
>9000
Super God
I recently had a revelation.  A new thought if you will, maybe it will tie in with your explainations?  Well, what if we had three segments of coil wound perpendicularly to a collector, like everyone is doing.  Put frequency x in one 2x in another, and x in the last.  Now, what if we made two more of these and put on underneath and one on top of the original?  Both the top and bottom could have half the frequency of the middle.  Does that sound plausible to you, Mark?
Thank you for your excellent documentation on spinors!
>9000
Bruce_TPU
EM said he was sorry.  I say for me, apology accepted.
"Hope deferred makes the heart sick."
So what is the cure?  ...HOPE
Many on this forum are experimenting with what we now know.  And what we do not know shall be found out, as small advancements continue.  I for one, do not care to hear any more S.M. theories, unless combined with experimentation.
We have enough to work with.  And that which we have is more than just theory.  That should give us hope.
The answer will, from here on out, be found at the bench.
Hang in there EM.  Time to build for real.  ;)
"What one man can do, another man can do!"
Cheers,
Bruce
starcruiser
Quote from: -[marco]- on July 16, 2007, 04:33:28 PM
hey Carl, you pic is missing  ;D
Yeah, I just noticed it, I'll have to check my webserver.
Regards,
Carl
