High voltage
Started by TheOne, July 18, 2007, 12:43:36 PM
TheOne
Can we use a Microwave Ovens transformer to generate high voltage from a 12 volt battery?
A Microwave Ovens transformer can usually convert 120V to 2500V, I was wondering if we can plug a 12V and hope something like 250v ?
Can we use it directly or we need some kind of circuit to be able to use it?
thanks
TheOne
The main purpose of this thread is for the use of Microwave Ovens with hydrogen cell, putting higher voltage on the cell using only a 12volts battery
Duranza
Seems to be like a good idea to try.. I have a few microwave ovens not being used, I might just give it a try...
The only way to Validate is to Replicate!
rapttor
I thought it might be worth giving a try using a MOT running off a Variac, but you have to externally "ballast" the MOT, or you will melt the secondary / and or blow the circuit breaker for sure.
Be very careful using MOT's, alot of the time, there's no second chance!
Here's some info on it:
http://www.kronjaeger.com/hv/hv/src/mot/index.html
Ballast info:
http://dawntreader.net/hvgroup/ballast.html
http://www.richieburnett.co.uk/ballast.html
Successfully Perpetually Failing at everything I do...
TheOne
but is using this with 12v will work and generate 250v ?
is ballast for this are cheap?
