Tubes?
Started by Super God, July 18, 2007, 06:46:18 PM
duff
Mannix
Thanks pese...
http://rayer.ic.cz/teslatr/vttce.htm...some good variations there...the tip of the berg!
The sooner we all start hooking these things up in any way that we can imagine and making some noise the sooner we will learn some of the things that the inventor learned.
Some specifics that i "THINK" are relevant
Tubes can operate hooked up to a coil where ss units failed to work.(directly i believe)
That means that ,as Pese said, something abnormal happens...we are searching for something abnormal. something that was over looked and not considered useful back when these were the latest technology......It was not really that long ago was it?
The drive signal i believe is not spikes but spikes are generated and perpetuated in the coil.....I could be wrong about that but it MUST be at least considered as a strong possibility.
The interactions between different parts of the circuit at different frequencies may be what was meant by "find the circuit potential".
Triodes have been pointed out as what to use....we know that we are below 10 mhz...way below.
pese
Some "answers , ideas , thinkings - refer to mannix :
---MANNIX  ''' ME .
###  Jes it?s so .
###  Nothing is annormal - only " unknow , not jet to understand - and "in-another- "level" of thinking and mind .
###  It shown possibel that spices and also other
signals (also "noise"!! ) can result an "unknow output(-power)".
## jes see above
Posibliy also Tesla" uses his70L7 that are "prentodes "
RCA say "gridbeam"  because its an copy from europe patents --- as TRIODE . in his electric car that worked
also in this frequencies . Tesa say : it can used "any
frequencies.  I myself , i belive he have used the fully
"radio-frequency ranges , that contains "in addition , an lot "hi power?) NOISE.
- The noise that you hear in radion betwenn the station . the "snow" in TV Set if transmitting have CLOSED , is the "noise" from "universe".
Pese
any pentode el84 el34 6l6 enz. can used
also astriode , wveb with electrical caracteristics of an triode..
for other details , some small "thinkings" soonest..
Pese
pese
@ Mannix
the "berg"  = "pic"
you find in the collection in this URL  !!
it give an lot to "study" for "searchers" "invertors" "hobbyists"
and so on
Gustav Pese
http://pese.cjb.net
innovation_station
ok guys i know we all want a working ring
but in order to have a working ring we were instructed to use tubes now when sm says tubes does he mean freq gennys? i dont think so the amp maybe  but he specfictly mentions the 6bq7a tube as a phase invertor could the phase invertor be some kind of pre amp adding the phase effect to the mix i think that it is and from the digging i have done i would say that it only flips the phase by what ever deg we select it to and with this peice of equipment we should be able to create a phase locked loop!!
anyone got any ideas?!?!?!
ist
this would be the area i have dirrected the least of my thoughts so  it will need work to achive our goal  ;)
