chrisC
Quote from: ltseung888 on July 31, 2008, 10:09:09 AM
Explaining the Bessler Wheel
Many people asked: "Is the Bessler Wheel theoretically possible?"
My answer is a definite yes.  In the figure below, we show a pendulum on the LHS; an unbalanced wheel in the middle and a possible Bessler Wheel on the RHS.
We know that the pulsed (or Lee-Tseung Pulled) pendulum can lead out gravitational energy.  Refer to the hundreds of posts in this thread.
That's why you're still looping in your head. NO, no one EXCEPT YOU AND YOUR MULTIPLE PERSONA believes this nonsense. You have never once provided conclusive proof. All we have in these hundreds of posts are statements from you as if they were Gospel! Sorry Lawrence, time to take some medicine again!
cheers
chrisC
Cap-Z-ro
Now we are getting somewhere...finally!
Consider this if you wood...if one, or possibly more people were able to regulate their urine flow into timed pulses...and direct the flow with a funnel and a hose (just for the funnel of it) so that it falls downward onto the bicycle wheel (by now having cupped paddles attached) thereby giving the wheel its required timely pulse.
Would this not be over unity of sorts...or at least over urinity ?
Regards...
Top Gun
Let me focus on the figure Bessler.jpg on reply 2958.
Most people who attempted to reproduce the Bessler wheel suffered from the following:
(1)   Produce a symmetric balanced wheel.  Note the two balls on the RHS.  They are of unequal weight.  This will make the wheel unbalanced.
(2)   Do not realize the importance of producing the pulses.  The middle simple unbalanced wheel will accelerate and decelerate.  But a mechanism is required to produce the sharply defined pulses.
(3)   The actual pulsing mechanism.  The RHS figure uses falling balls with unequal weight and padding.  Other examples use hammers and weight shifting configurations.  There are many possibilities.
(4)   The matching of the rotational speed and the pulsing mechanism.  This is the most difficult part of the experiment.  Hunting for resonance by repeated experiments is a painful process.  A configuration may seem promising.  Then rusts or other factors come in and changed the conditions.  The result is no longer reproducible.
(5)   Many inventors do not trust simulation software, as they believe that the software would just apply the Law of Conservation of Energy blindly.  Such software did not consider lead-out-energy.  If such software were modified to take lead-out-energy into account, the result will be different.
(6) Without the guidance of aimulation software, the process becomes a game of hit and miss.  Some claimed that they produced a working prototype.  Others could not reproduce it.  The hammering mechanism is a good example.  It is almost impossible to have two spring hammers behaving exactly enen though they are made from the same long spring.  Some produced the unbalanced wheel by accident as their crude methods could not produce a perfectly balanced wheel.
I am confident that the Bessler Wheel (or the unbalanced wheel using lead-out gravitational energy) can be reproduced if the experimenters understand the above theory.
Personally, I would not waste time because the Wang or Bedini type systems are much easier to reproduce.  It is like producing man-powered flight.  It is possible but the plane with an engine is much easier to produce.
Pirate88179
Hey, I just figured out that my Grandfather clock is an overunity device as defined by Lawrence's theory.  You see, the spring, when you wind it up, through the gearing and detent devices, applies the perfect Lee-Tseung pulses to the pendulum at exactly the correct time. (no pun intended)  This is a perfect example of a pendulum leading out gravitational energy.  I don't know why I am the first to discover this.  This should at least earn me an honorable mention at the Nobel Prize ceremonies.  Of course, we have to ignore any energy imparted from the winding of the spring by our hand, and the spring to the pendulum, and the weights we have to lift against gravity, but hey, other than that, it is pure overunity with gravity being lead out. At least I am now on the record for this amazing discovery.
chrisC
Quote from: Pirate88179 on July 31, 2008, 09:20:09 PM
Hey Bill. Wait a moment. My grandpa also had a wound up pendulum like your grandpa! Now that makes two of us to co-discover this magic Lee-Tseung Push (or was it Pull?) . Now can I also go to the Noble Prize ceremony or at least gain another honorable mention?
Anyone else out there whose grandpa owns one of there perpetual motion machines utilizing the Lee-Tseung hocus pocus mechanism? Hurry.....
cheers
chrisC
