0 Members and 63 Guests are viewing this topic.
ltseung888
Professor Logical: “Let me examine the Tong Po Chi device in detail.”
The components as shown in the diagram Tong1.jpg are as follows:
1.   The 12 Volt DC battery.  The negative side wire is attached.  This can be any suitable DC power supply.
2.   The transparent tube to hold the permanent magnet.  It has an optional top piece for the collision.  However this top piece can be taken out.  The electromagnetic Coil 3 will provide the magnetic attraction to present the permanent magnet from jumping away.
3.   The top Coil or electromagnet with more winding.  It is fixed in position by two black rubber rings.  When DC current is passed, it will attract the permanent magnet inside the transparent tube 2 â€" giving in an upward momentum in this configuration.  As soon as the permanent magnet passes through the middle of the Coil, the magnetic force will attract the magnet back â€" producing a downward force to prevent the permanent magnet from flying away.
4.   The bottom Coil with less winding.  It is fixed in position by tow black rubber rings.  When DC current is passed, it will repel the permanent magnet â€" giving it an upward momentum in this configuration.  For the experiment, this bottom Coil may be removed without affecting the result.
5.   A loose stand to allow the transparent tube 2 to remain in the upward position.
6.   The lead to the positive side of the battery.  It is disconnected when the picture was taken.
7.   A commercially available timer.  This timer can be adjusted in the range form 0.1 second to hours.  We use its off/on function.  For example, when we set it to 1 second, the DC current is on for 1 second and then off for 1 second.  The process is then repeated.  This provides the jumping action.
Richard: “There is no magic in the Tong Po Chi device.  All the parts can be purchased or homemade.  The cost is less than HK$500 (or US$70).”
Nancy: “You do not need to send the battery to the various universities for verification.  The cost will then be less than HK$150.  The postage will be cheap too.  The contents may pass the security checks too.”
Professor Logical: “This basic platform is good enough to convince me.  I accept the theory that an unbalanced force can be produced for propulsion purpose in a closed system.”
Richard: “The WBLT device is more than a hamburger.  I am excited.”
Nancy: “Now you mention it.  I feel hungry.  Let me be the host and treat you all -  how about WBLTs at Wendy's?”
ltseung888
Richard: "Professor Logical, Please comment on the Tseung belief that the Chinese, USA and other Countries may have already developed flying saucers."
Professor Logical:"I would believe the Government version that there are no UFOs previously.  Now, I know how to build it.  I know that the known Physics Laws allow the building of such devices.  I also know that the technology is within the capablities of our top engineers.  It is logical to assume that there are top-secret projects from various Governments."
Nancy:"What will happen to Tseung et al?  What will happen to their less than HK$500 research device?"
Professor Logical"I believe some Governments may fund debunkers to discredit Tseung et al.  They may even claim that the experimental results are faulted.  However, if Tseung moves along the present path of triple confirmation and explains every step, the debunkers will only make a fool of themselves."
Richard: "The Earth is round no matter what the authorities say."
Nancy kissed Richrd on the cheek.  They know that they will not be the targets of Secret Agents.
chrisC
Quote from: ltseung888 on January 27, 2009, 06:55:21 PM
And so, the clown deludes himself for another day ......
cheers
chrisC
hansvonlieven
A mechanical version of the Tong Po Chi device has been around for a very long time. It is called a Pogo Stick. Not many of them fly across the skies.
Hans von Lieven
hoptoad
Quote from: hansvonlieven on January 27, 2009, 07:27:09 PM
Hans von Lieven
Flying Pogo Sticks are very rare like Flying Pigs!  :P
Caution, don't hold your breath while waiting to see one.
