0 Members and 197 Guests are viewing this topic.
hansvonlieven
Stop with this crap Paul, it's irrelevant.
Fact is that under the conditions outlined by top Gun or whatever else he calls himself NO surplus energy has ever been demonstrated or observed!
That is all that matters. Fancy theories or postulates mean nothing until they are demonstrated to be true.
Hans von Lieven
chrisC
Quote from: Paul-R on February 26, 2009, 07:16:37 AM
Hans, four simple questions.
1. Have you heard of the Nobel Physics Prize winners for 1957, Messrs Lee and Yang?
2. If so, please explain their relevance to us on overunity.com
3. Have you heard of Hal Puhoff's fabled saying about enrgy and its availability?
4. If so, please explain their relevance to us on overunity.com
Paul.
Looks like your mind is going the same direction as the Lee-Tseung Hot Air Theory. No wonder you bothe think alike. No more questions. Thank you.
cheers
chrisC
Top Gun
I shall present my version of the programming for the Lead-Out-Energy Pulse Motor here:
Starting Phrase:
1.   Set all Coils to Drive Coil Mode
2.   Start the clockwise rotation (by hand if necessary)
3.   If the magnets are just below the coil positions, turn on current to provide magnetic propulsion.  The wheel should rotate faster.
4.   If the speed is not fast enough, loop back to 3.
Operational Phrase:
5.   Else set one Drive Coil to Collector Coil Mode and use the electricity.
6.   If the speed is still fast enough, repeat 5 with one more Coil to Collector Coil mode.
7.   If the resulting voltage from the Collector Coils is large enough, recharge the batteries.
8.   If the speed is too fast (too little external load), set one Drive Coil to Neutral until the speed is at the desired (or designed) level.
9.   If the speed is too slow (too much external load), set a Neutral Coil to Drive Coil Mode.
10.   If there were no more Neutral Coils, flash warning light to warn user that the capability of the device has been reached.  Turn on the protective circuit to limit the electricity drawn out.
Closing Phrase:
11.   Is the Closing Switch on? If not, continue Operational mode.
12.   If yes, check if the batteries are fully charged.  If not, cut electricity supply to outside and continue charging.
13.   Turn device off
The above logic may not be perfect.  But it is a good starting point for scientific discussions.  One hidden assumption is that there is lead-out-energy.  The higher the rotational speed, the higher the lead-out-energy.  Another hidden assumption is that the efficiency of the device is such that the lead-out-energy is large enough to overcome internal losses.
chrisC
Quote from: Top Gun on February 26, 2009, 07:44:48 PM
  One hidden assumption is that there is lead-out-energy.  Another hidden assumption is that the efficiency of the device is such that the lead-out-energy is large enough to overcome internal losses.
It's the same assumption your friend Paul_R made about donkeys being able to play chess.
Well, some 'scientist' do believe that. We've seen 400 pages of testimony so far.
Need we go any further?
cheers
chrisC
ps: sorry Stephan, you're paying for more bytes in exchange for our need for comedy on the Overunity Forum.
hansvonlieven
@ Top Dork
You say: The above logic may not be perfect.  But it is a good starting point  for scientific discussions.  One hidden assumption is that there is lead-out-energy.  The higher the rotational speed, the higher the lead-out-energy.  Another hidden assumption is that the efficiency of the device is such that the lead-out-energy is large enough to overcome internal losses.
Instead of hidden assumption put idiotic assumption and you will have it right
Hans von Lieven
