0 Members and 44 Guests are viewing this topic.
chrisC
Quote from: ltseung888 on May 27, 2009, 04:42:56 PM
The person on the LHS is a very tired Mr. Lung.  He is helping to turn the prototypes into educational products.
The box on the RHS may be a box that you can purchase at around Christmas time this year.  If there were delays, you may purchase such a product at the World Expo in Shanghai in 2010.  The overunity pulse motor will be part of the package.
It'll be a LUNG LUNG time (if ever) before we see O.U stuff from you entourage Mr. tseung.
cheers
chrisC
ltseung888
http://www.absoluteastronomy.com/discussionpost/_10712
There were ten participants in the mini-internal demonstation on May 28.
The actual powerpoint presentation was repeated twice as one important person came an hour early. That turned out to be a blessing as that dry-run helped to make the later presentation much more smooth.
Every participant used his/her figure to start the Tong Pulse Motor. They all saw how the input and output measurements were taken. There was little doubt that the Input Voltage was 12V as that was from a battery. The new coils have 50 ohms resistance and that measurement was repeated many times.
They could all see that the Output Voltage reached 60 Volts AC. There was a small panic as one of the coils dropped out and after connecting back, the Output Voltage was only 45 Volts AC. It turned out that the two ends of the coil was unintentionally misconnected. That turned out to be a good lesson. Even though the output was AC, we still needed to be careful about the connecting wires in the pulse generator. (We do not need to care on the output load.)
The focus of the discussion turned to "whose figure" we should use at United Nations. A number of improvement suggestions on the presentation and the technical set up were raised.
The most important technical point was that with the same type of coils for drive coil and collector coil, overunity can be achieved if the total output voltage (DC) can be demonstrated to be higher than input.
Sigh. Once again it seems, Lawrence, that you haven't done your homework, and even if you did, you copied someone else's papers.
Are you at all aware that Kohei Minato has a patent covering your pulse motor design? For your reading pleasure, I have attached a copy of his application including drawings. Pay special attention to the Claims, and to Drawings 9 - 12.
Oh, and by the way, in 2000, Joe Firmage's group ISSO tested Minato's pulse motor/generator, for which he was making almost identical claims as you are above, and using his own instrumentation, they identified the basic sophomore EE error in his computations and showed that, far from OU, his motor/generator was about 34 percent efficient. Not so good as these things go nowadays.
Maybe that's why he couldn't close the loop and make it run itself.
Why can't you close the loop and make your pulse motor run itself? Because it isn't OU, that's why.
(Volts aren't power, power isn't energy, bada-bing.)
(It appears that the pdf file is too big, so here's the link to another post in this forum that has it linked.)
http://www.overunity.com/index.php?topic=846.0
chrisC
Quote from: TinselKoala on May 28, 2009, 06:04:22 PM
@TK
Well, you see Lawrence supposedly got a degree in Aeronautical studies in the U.K. Recently he switched to learning elementary electronics after failing to attract followers to his mechanical lead-out pendulum mumbo jumbo Physics. After playing around with coils, batteries and resistors he got very excited because he could make the Tong Po Chi device 'jump'! One thing led to another and so we are here today because Lawrence sincerely believed he's inventing the pulse motor!
Our soap opera continues a new season with a new topic. However the cast is probably going to accept another season of assignment unless Lawrence invites new personalities?
cheers
chrisc
ltseung888
Kohei Minato's "Magnetic Rotating Motor Generator" US Patent application
« on: March 14, 2006, 08:17:09 PM »Quote I've attached a copy of the ""Magnetic Rotating Motor Generator" US Patent application to this message.
The inventor, Kohei Minato, claims the following:
"The present invention relates to a magnetic rotating motor generator that a motor which is subject to magnetic rotational drive semipermanently performs predetermined work (e.g., rotation of a fan or drive of a mechanical shaft) in a rotation mode and, at the same time, has a power generation mode for performing power generation, output power is larger than input power for driving the motor and power regeneration is possible."
I see some similarities between Kohei Minato's motor and Paul Splain's motor:
1) it is claimed that the output power is larger than the input power. (IE. overunity)
1) there is an electromatic that 'kicks' the rotor on a regular basis so it doesn't get 'stuck'
2) the magnetic flux that the rotor sees from the magnets is not a constant all the way around the stator. In Paul Splain's motor this is done by changing the distance of the magnets from the rotor. In Kohei Minato's motor this is done by changing the angle of the magnets so they aren't perpendicular to the rotor.
The Minato, Newman and Bedini Motors relied on pulse with one frequency.  At other "non-optimal" frequencies, the efficiency would be low and cannot achieve overunity.
The 225 HP Pulse Motor and the Liang Generator relied on tunable or programmable frequencies.  That is why that they were successful and classified by Governments.
The Tong Po Chi Pulse Motor in our garage laboratory has variable frequencies.  It is not programmable yet.  However this property allows it to produce the overunity condition over a wider range.  We know that it has significant output because if we did not put on external load, the electronics will burn!
It is just a matter of tuning now.  The overunity factor is 16 and the output power is 50 watts.  We expect to improve that significantly in the coming weeks.  (We believe that one slice of the 225 HP pulse motor could indeed provide over 20 HP.  That is theoretically possible.  It is classified but we feel confident that Obama will declassify it when our inferior version gets demonstrated at United Nations.)
