Paul-R
Quote from: ltseung888 on November 29, 2009, 04:13:12 PM
At present, our collector Coils do not have any soft iron core.  If we put soft iron core in at the beginning, the coil will be attracted to a permanent magnet on the wheel.  The wheel will not rotate at all.
It might be that the device needs to be driven at a certain RPM. Why not try
forcing it to rotate at a speed which will mean that certain frequncies will be
induced. you could chase around for resonance, and a sudden sharp hump
in the performance curve.
ltseung888
The Inno Dessign Tech Expo is a very mcuh larger Show.
Over 5,000 people visited our booth on the first day.  We were interviewed by the Mainland TV on their innovation program.  The Lead-Out Energy Machine and the Slides will be seen by possibly 1.3 billion viewers.
teslaalset
Quote from: ltseung888 on December 03, 2009, 09:05:37 AM
Much success at the show, Lawrence.
I guess you will not have 5KW at hand for the show.
That needs to wait for a maturity period that is more realistic.
chrisC
Wow! 1.3B fellow Chinese now knows you've discovered sliced bread!
Time to rejoice indeed. When's the flying saucer showing up?
Maybe in the interim you can get the HK sweat shops to churn out miniature plastic flying saucers at $10 HK each. Then you won't need to work so hard at your scams on this site?
cheers
chrisC
markdansie
Hi ChrisC
I have been away again,
nothing new to see other than a 1 watt device will weigh under 20kgs. Can't weight for the test results for that one. So rather than use my government subsidised solar panels, I can install a 20 ton machine as a much more feasible replacement.
@man in funny white hat (goes well with the suit)
PS where is the 5 kw device?
Where are the independent University tests as promissed?
What ever happenned to the UFO's,at least that was entertaining.
When is the next expo?
How many paid the $20,000 for the course?
Kind Regards
Mark
