The Lee-Tseung Lead Out Theory
Started by ltseung888, July 20, 2007, 02:43:44 AM
chrisC
Quote from: Devil on August 29, 2008, 05:25:40 PM
The first draft could not pass the reviewers.  One of them is I, the Devil.
The book is supposed to be second only to the Bible.  There is much revising to do.
Get a life Old Tseung. Use your time for really benefiting orphans or something more useful. No one impressed by you masquerading as TopDog (TopGun?) or Devil or whatever mind games you want to play.Remember people in their sixties should not behave like this!
cheers
chrisC
chrisC
Quote from: hansvonlieven on August 28, 2008, 02:58:58 AM
WHATEVER HAPPENED TO THE SPACESHIP THAT WAS
SUPPOSED TO FLY OVER THE OLYMPICS?
I guess it got diverted to Aldebaran.
Hans von Lieven
Well, I just found out Tseung was right after all. The Nanjing Flying saucers are all over China now that the Olympics are over!
Look! No kidding!
cheers
chrisC
Pirate88179
@ chrisC:
Actually, to be more accurate, that is a very old photo of Professor Whoflungdung playing as a child.  You can clearly see from the photo that, even as a boy, he had no problem creating and flying a real flying saucer model.  One interview I had read about him states that, as he got older and read of the legendary Piss Mobile concept developed by Hans VonLieven, he tried the idea.  He charged up the engine with piss and gave the saucer a light toss.  Reports are that the small toy saucer bounced off of the moon shortly thereafter and departed for points unknown in deep space.
This was several years ago and the Professor believes the saucer to be flying as of today. Where?  No one knows.
Bill
ltseung888
Theory behind the lead-out-energy inventions (e.g. Wang)
We can classify machine into three types.
(1)   Output energy plus loss is equal to input energy.  This is the traditional form of machines.  There must be continuous supply of input energy for these machines to function.
(2)   Output energy is larger then input energy.  These are known as over unity machines.  They violate the Law of Conservation of Energy.  Energy is created from nothing.  Such machines are regarded as impossible perpetual motion machines.
(3)   Input energy will lead out other forms of energy such as gravitational or electron motion energy.  The concept was publicly described in the PCT patent titled ?Extracting Energy from Gravity? by LEE Cheung Kin and TSEUNG Lawrence Chun Ning.  The number is PCT/IB/2005/000138 and published on July 27, 2006.  (http://www/wipo.int/petdb).  Our invention (Wang) belongs to this class of machines.  Thus our invention does not violate the Law of Conservation of Energy.
In this type of lead-out-energy machines, the input energy can lead out existing energy.  For example, in the case of a pulled pendulum under a horizontal input force, approximately 2 parts of horizontal input energy can lead out 1 part of vertical gravitational energy.  3 parts of energy appear on the output.  1 part can be used to do work or generate electricity.   2 parts of the output energy can be fed back to the input to lead out another 1 part of gravitational energy.  Thus the lead-out-energy machines require only 2 parts of starting energy and they can continuously lead out gravitational energy to do work.  They do not violate the Law of Conservation of Energy.  They do not create energy from nothing.  They use existing gravitational energy.
In the Lee-Tseung PCT patent, they extended the above concept to pulsed rotational systems in magnetic fields.  Magnetic or electron motion energy can be led out in a pulsed rotational system.  More information on the Lee-Tseung theory is available on the Internet (http://www.energyfromair.com/IOE_talk) or via the Book by Lawrence Tseung titled ?Innovation ? the story of Lawrence Tseung?.
The Wang invention is a coupling of two pulsed rotational systems in magnetic fields.  The first is ferro-liquid rotation.  The second is permanent magnet rotation.  Both systems can lead out magnetic or electron motion energy.  The quantity of electricity that can be generated will depend on the strength of the magnetic fields, the speed of rotation, the mass of the rotating parts and the radius of the rotating system.  There are additional design features such the number of magnets, the orientation of these magnets and the use of magnetic shielding material.
The full description of the Wang set up is described in the product description section.
*** The above short theoretical description is likely to appear on all lead-out-energy invention announcements.
Devil
Quote from: ltseung888 on August 31, 2008, 09:44:39 PM
Tseung, with an increasing number of worldwide announcement and demonstration of lead-out-energy products using the above quote, you book will indeed have sale only second to the Bible.
Make sure that it is of the highest quality.
Do not worry about the insults and jeers.  Let them recite the following 666 times.
(1) The Lead-out-energy from a horizontally pulled pendulum is equal to the vertical component of the tension times the vertical displacement.
(2) An unbalanced force can be generated from a closed system.  Secondary events using unequal exchanges of energy and momentum are used.
(3) The electromagnetic Coil can be a magnet, a collision mechanism and an electricity exchange mechanism.
